メインコンテンツにスキップ
Sony Pulse Elite Edition Battery Replacement
必要な工具と部品
  1. Sony Pulse Elite Edition Battery Replacement, Identifying Earpiece: 手順 1、 1の画像 1
    • Locate the left side designation on the headband-earpiece junction.
    • The battery is in the right earpiece.
    • The motherboard is in the left earpiece.
  2. Sony Pulse Elite Edition Battery Replacement, Ear Cushion Removal: 手順 2、 2の画像 1 Sony Pulse Elite Edition Battery Replacement, Ear Cushion Removal: 手順 2、 2の画像 2
    • Gently pull around the perimeter of the left ear cushion until it comes off.
  3. Sony Pulse Elite Edition Battery Replacement, Outer Ear Rim Removal: 手順 3、 2の画像 1 Sony Pulse Elite Edition Battery Replacement, Outer Ear Rim Removal: 手順 3、 2の画像 2
    • Use the PH00 Screwdriver to remove the three Phillips 6mm screws around the perimeter of the ear cup.
    • Gently pull the outer ear rim off of the headset assembly.
    • Harsh removal may cause permanent damage to the speaker wires.
  4. Sony Pulse Elite Edition Battery Replacement, Remove Speaker Housing: 手順 4、 1の画像 1
    • Using tweezers, gently pry the red and black speaker wires from the attached socket.
  5. Sony Pulse Elite Edition Battery Replacement, Remove Battery: 手順 5、 2の画像 1 Sony Pulse Elite Edition Battery Replacement, Remove Battery: 手順 5、 2の画像 2
    • Lift up battery and disconnect wires using tweezers.
    • Use a new battery for reconstruction.
終わりに
8 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Chris Echter
メンバー登録日: 01/29/15
865 ポイント
4のガイドは作成済み
チーム
Clemson, Team 14-2, Shirley Spring 2015 Clemson, Team 14-2, Shirley Spring 2015人のメンバー
CLEM-SHIRLEY-S15S14G2
5 メンバー
12のガイドは作成済み
7 件のコメント
Where can I buy the replacement battery for this?
Pretty hard to find...
francisklalumiere - 返信
Replacement batteries can be found by googling "SP70C battery". It is a Lithium battery with 900mAh and a 3.7v output. AliExpress shows them for $11 including shipping.
David McAndrews - 返信
Can I mod and replace the battery with a bigger one with no white connection, just positive and negative? Thanks!
marit - 返信
Thank you so much for this guide. I got a 1000mAh batter from Amazon for 10 dollars. It lasts way longer and was extremely easy to install. Very thankful for this. Thanks!
sharku19z - 返信
i just attempted... the connector to the battery just pulled off. NOTE: Pull up from PCB not out. The connector sets down into it.
Garrett Parmenter - 返信
you didn’t show how to remove the inner ring that holds the battery in, looks very fragile and I don’t want to break it
brimest0ne - 返信
brimest0ne, the inner ring is fastened down by the same three screws originally removed in step three! When you remove the inner ring, the bass volume adjustment side will give you a little resistance, just be gentle and it comes right off. That’s it, now replace the battery and start using the headset again! What I really want to know, has anyone done an upgrade will battery replacement and how much more time are you getting from the upgrade?
helliant1 - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 41
今までの合計 10,541
