この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
This guide will aide you in performing the replacement of the Sony PlayStation Camera's microphone array.
The outer case will scratch easily if the device is not handled with care during the opening process. If the aesthetics don't matter to you, this will not be a problem.
Finding the seam to start the case separation can be difficult. Using a flashlight, or very well lit area, can help to find the seam under the right angle. This can be helpful during this step.
必要な工具と部品
Separate the camera from the camera stand to gain access to the bottom of the camera.
ある他の人がこのガイドを完成しました。
