メインコンテンツにスキップ
  1. Remove the base by pushing in the button and sliding out the unit. Remove the base by pushing in the button and sliding out the unit.
    • Remove the base by pushing in the button and sliding out the unit.
  2. Remove USB port cover from back plate with a metal spudger. This will prevent the cover from falling under the back plate once it is removed. This will prevent the cover from falling under the back plate once it is removed.
    • Remove USB port cover from back plate with a metal spudger.
    • This will prevent the cover from falling under the back plate once it is removed.
  3. With the  Phillips #02 screwdriver, remove the six 6 mm length x 6 mm head screws from the back plate. With the Phillips #02 screwdriver, remove the ten 6 mm length x 8 mm head screws from the back plate.
    • With the Phillips #02 screwdriver, remove the six 6 mm length x 6 mm head screws from the back plate.
    • With the Phillips #02 screwdriver, remove the ten 6 mm length x 8 mm head screws from the back plate.
    • These screws have different threads and need to be kept separate.
  4. Remove back plate with a plastic opening tool by slowing prying around the entire plate. Be gentle to avoid breaking the plastic clips which hold the plate. Once separated the plate easily lifts off.
    • Remove back plate with a plastic opening tool by slowing prying around the entire plate.
    • Be gentle to avoid breaking the plastic clips which hold the plate.
    • Once separated the plate easily lifts off.
終わりに
2 の人々がこのガイドを完成させました。
Tia McNaughton
メンバー登録日: 2015年10月01日
379 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 12-16, Maness Fall 2015 Cal Poly, Team 12-16, Maness Fall 2015人のメンバー
CPSU-MANESS-F15S12G16
4 メンバー
8のガイドは作成済み
コメント1件
I got a used display that for some reason came with no screws on the back panel. Can you tell me exactly what type those 6x6mm and 6x8mm screws are? Especially wary since you said the thread sizes are different
Kodi Taylor - 返信
コメントを追加
統計データを表示:
過去 24時間: 3
過去 7 日: 23
過去 30 日: 43
今までの合計 1,711
