メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
To complete this Sony NWZ-E473 guide, a soldering iron will be needed. You may want to have someone with soldering iron experience complete that step or watch some basic videos on how to use a soldering iron.
  1. Use a Phillips #00 screwdriver to unscrew the two 5 mm screws located on the bottom of the back of the device.
    • Use a Phillips #00 screwdriver to unscrew the two 5 mm screws located on the bottom of the back of the device.
  2. Use a plastic opening tool to loosen the bottom portion of device.
    • Use a plastic opening tool to loosen the bottom portion of device.
  3. Use a plastic opening tool to loosen the top panel of the device.
    • Use a plastic opening tool to loosen the top panel of the device.
  4. The Essential Toolkit
    コンパクト版iFixitキットの中で最も利便性の高いツール
    ショップを見る
    ショップを見る
  5. Use a Phillips #00 screwdriver to remove the two 3 mm screws located on the portion under the top panel of the device.
    • Use a Phillips #00 screwdriver to remove the two 3 mm screws located on the portion under the top panel of the device.
  6. Remove the back plate from the device. Remove the back plate from the device. Remove the back plate from the device.
    • Remove the back plate from the device.
  7. Peel back the layer of tape along with the processor, which is located just below the battery, using the tweezers and the spudger. Peel back the layer of tape along with the processor, which is located just below the battery, using the tweezers and the spudger.
    • Peel back the layer of tape along with the processor, which is located just below the battery, using the tweezers and the spudger.
  8. Slide a prying tool underneath the top portion of the battery and lift it from the case. Slide a prying tool underneath the top portion of the battery and lift it from the case.
    • Slide a prying tool underneath the top portion of the battery and lift it from the case.
  9. Remove the stickers from the battery terminals, which are on the underside of the battery.
    • Remove the stickers from the battery terminals, which are on the underside of the battery.
  10. Use a soldering iron to remove the wires from the red and the black terminals.
    • Use a soldering iron to remove the wires from the red and the black terminals.
終わりに
4 の人々がこのガイドを完成させました。
Matthew Hintz
メンバー登録日: 2015年01月16日
327 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team 17-6, Watkins Winter 2015 USF Tampa, Team 17-6, Watkins Winter 2015人のメンバー
USFT-WATKINS-W15S17G6
4 メンバー
5のガイドは作成済み
2 件のコメント
Hi their I have a Sony nwz-e355 walkman I want to replace the battery in it cause I thinks it's done I see u do a replacement for the e473 wondering if u have e355 batteries or will this e473 battery work in my walkman both need to be soildered in any feed back would help
Derek Hebert - 返信
I have the same model. I have 2 of them purchased years ago from Ubid.com. A very cool device. SONY ought to service them when the batteries fade…
guy lewit -
コメントを追加
統計データを表示:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 35
今までの合計 8,108
