この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
The replacement of the rear casing requires removal of multiple screws around the entire camera and inside the battery pack. Once the fasteners are removed, you can carefully pry off the rear case.
必要な工具と部品
Open the battery pack door by moving the slider to "OPEN".
Remove the 3.25 mm silver screw inside the battery pack with a Phillips screwdriver.
Remove the three (3.5 mm) screws from the bottom of the camera with the Phillips screwdriver.
ある他の人がこのガイドを完成しました。
