メインコンテンツにスキップ
Sony MDR-XB450AP Extra Bass Headphones Swivel Plastic Cover Replacement
必要な工具と部品
  1. Sony MDR-XB450AP Extra Bass Headphones Swivel Plastic Cover Replacement, Swivel: 手順 1、 1の画像 1
    • Begin by laying the headphones down flat with the speakers facing up.
    • Be sure to unplug the headphones from any other devices.
  2. Sony MDR-XB450AP Extra Bass Headphones Swivel Plastic Cover Replacement: 手順 2、 2の画像 1 Sony MDR-XB450AP Extra Bass Headphones Swivel Plastic Cover Replacement: 手順 2、 2の画像 2
    • Next, take out the screws that hold the front plate, using a J00 screwdriver.
    • Repeat for both the left and right screws.
    • These screws are very small. It is helpful to have a spot prepared to put the screws to avoid losing pieces.
  3. Sony MDR-XB450AP Extra Bass Headphones Swivel Plastic Cover Replacement: 手順 3、 1の画像 1
    • Now that the screws have been removed, pull away the plastic casing that covers the swivel piece (directly above the speaker).
  4. Sony MDR-XB450AP Extra Bass Headphones Swivel Plastic Cover Replacement: 手順 4、 1の画像 1
    • Now that the swivel piece is exposed, use a J00 screwdriver to unscrew the center screw.
    • Repeat this process on both sides if necessary.
    • This center screw is the piece that retains the swivel action, unscrew completely and remove to replace.
  5. Sony MDR-XB450AP Extra Bass Headphones Swivel Plastic Cover Replacement, Swivel Plastic Cover: 手順 5、 1の画像 1
    • With the swivel screw removed, remove the plastic casing.
  6. Sony MDR-XB450AP Extra Bass Headphones Swivel Plastic Cover Replacement: 手順 6、 1の画像 1
    • Using a little amount of force, slide the plastic cover off of the headband.
  7. Sony MDR-XB450AP Extra Bass Headphones Swivel Plastic Cover Replacement: 手順 7、 1の画像 1
    • Pull the plastic until the cover is fully removed.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Terrance Gallaher
メンバー登録日: 01/18/17
870 ポイント
5のガイドは作成済み
チーム
Eastern Washington University, Team 2-7, Crane Winter 2017 Eastern Washington University, Team 2-7, Crane Winter 2017人のメンバー
EWU-CRANE-W17S2G7
2 メンバー
14のガイドは作成済み
コメント 1 件
Necesito la pieza, dónde la compro?
lucas2188 - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 8
今までの合計 3,264
