メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Sony ICFC1T Battery Replacement
必要な工具と部品
    1. Sony ICFC1T  Battery Replacement, Battery: 手順 1、 2の画像 1 Sony ICFC1T  Battery Replacement, Battery: 手順 1、 2の画像 2
      • Remove the battery compartment from the underside of the device.
      • With your thumb and index finger, pinch the tab and pull gently until the compartment is released.
      • Always ensure that the device is unplugged before tampering with it to ensure there is no risk of electrical shock.
      FixBotに聞いてみる
      コメントを追加
    2. Sony ICFC1T  Battery Replacement: 手順 2、 1の画像 1
      • Take out old battery by pressing from the side marked "PUSH" on the compartment, and replace with a new battery, positive side up.
      FixBotに聞いてみる
      コメントを追加
    3. Sony ICFC1T  Battery Replacement: 手順 3、 1の画像 1
      • Replace the battery compartment into the bottom of the device.
      • Reset the time of the clock.
      • Plug your clock back in as to not rely on the back up battery.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
3 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Anna Graetz
メンバー登録日: 01/30/15
258 ポイント
1ガイドが承認済み
チーム
University of Kentucky Louisville, Team 1-5, Rountree Winter 2015 University of Kentucky Louisville, Team 1-5, Rountree Winter 2015人のメンバー
LOUISVILLE-ROUNTREE-W15S1G5
3 メンバー
20のガイドは作成済み
9件のガイドコメント
Thank you so much for creating this. :)
LadyLion - 返信 共有
step 2--I can't get the battery out of the compartment. Am I not pushing hard enough? Should I take a screw driver to pry it out? I'm afraid of breaking the compartment since it's only plastic.
Iris - 返信 共有
The battery does not prevent the display/clock from switching off when I unplug the cord. Is the purpose of the battery not supposed to be to retain power even when unplugged? I have already put in a replacement one, presuming the one that came with it to be faulty. How do I get this to work?
Is the original Sony one meant to charge up or something? Please help as it doesn’t seem right if back up battery function does not do it’s job.
KIRSTY MCNICOL - 返信 共有
The back up battery doesn’t seem to do it’s job. Unit switches off when unplugged. Is it the case that the original Sony battery charges? I assumed ut to be flat, replaced the battery but this doesn’t retain the power either
Is my clock faulty? How to engage the back-up battery?
@kirstyonline Kirsty, as the battery description says, it is only backup. So not for full device powering, but only to back-up time status while mains power is down. Unfortunately, this device is only capable of running from mains.
Radoslav Gulik - 返信 共有
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 28
過去 30 日: 128
今までの合計 18,630
