メインコンテンツにスキップ
Sony ICF-C1iPMK2 Control Buttons Replacement
必要な工具と部品
  1. Sony ICF-C1iPMK2 Control Buttons Replacement, Control Buttons: 手順 1、 3の画像 1 Sony ICF-C1iPMK2 Control Buttons Replacement, Control Buttons: 手順 1、 3の画像 2 Sony ICF-C1iPMK2 Control Buttons Replacement, Control Buttons: 手順 1、 3の画像 3
    • Remove the 1 cm Phillips #00 head screws.
    • Use a plastic spudger to pry the back chassis away from the front.
  2. Sony ICF-C1iPMK2 Control Buttons Replacement: 手順 2、 3の画像 1 Sony ICF-C1iPMK2 Control Buttons Replacement: 手順 2、 3の画像 2 Sony ICF-C1iPMK2 Control Buttons Replacement: 手順 2、 3の画像 3
    • This step contains ribbon cables. Be careful to not bend or rip these fragile cables, to protect your device.
    • Open the back chassis.
    • Remove the top ribbon cable by pulling it straight out of the port.
  3. Sony ICF-C1iPMK2 Control Buttons Replacement: 手順 3、 3の画像 1 Sony ICF-C1iPMK2 Control Buttons Replacement: 手順 3、 3の画像 2 Sony ICF-C1iPMK2 Control Buttons Replacement: 手順 3、 3の画像 3
    • Disconnect the power connector.
    • Disconnect the AUX port connector.
    • Slide the buttons out of the front chassis.
  4. Sony ICF-C1iPMK2 Control Buttons Replacement: 手順 4、 2の画像 1 Sony ICF-C1iPMK2 Control Buttons Replacement: 手順 4、 2の画像 2
    • Remove the 1 cm Phillips #00 screws on the board.
    • Pull the plastic buttons off of the housing.
  5. Sony ICF-C1iPMK2 Control Buttons Replacement: 手順 5、 2の画像 1 Sony ICF-C1iPMK2 Control Buttons Replacement: 手順 5、 2の画像 2
    • This next step requires soldering. Be careful when handling a soldering iron as you can easily burn yourself on it and the hot liquid solder. Make sure to desolder and solder in a well ventilated area to not inhale heavy metals, possibly lead. (If you buy iFixit solder there will not be any lead in the solder, but it is still best practice)
    • Place the soldering iron onto the solder joint of the broken button.
    • Once melted, remove the button, being careful to not touch the melted metal.
    • Replace the button and touch the soldering iron to the solder wire over the button contacts. Refer to the prerequisite guide if you need more help.
終わりに
Give the new solder 30 to 45 seconds to cool before reassembling.
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
KyndleGabel
メンバー登録日: 09/15/23
530 ポイント
3のガイドは作成済み
チーム
University of North Texas, Team 6-5, Kilpatrick Fall 2023 University of North Texas, Team 6-5, Kilpatrick Fall 2023人のメンバー
UNT-KILPATRICK-F23S6G5
5 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 10
今までの合計 101
