はじめに
This step-by-step guide will allow you to follow along and replace the faulty speaker of your device.
必要な工具と部品
Using a Phillips #00 screwdriver, remove the four 14mm screws from the underside of the device.
Use the plastic opening tool and the spudger to separate the speaker from the device by tracing its outline and loosening the glue.
what is the dimension power and ohm of the speaker? thanks you! the original hear very bad…
ある他の人がこのガイドを完成しました。
