メインコンテンツにスキップ
Sony ICF-C1T Speaker Replacement
必要な工具と部品
  1. Sony ICF-C1T Speaker Replacement, Speaker: 手順 1、 2の画像 1 Sony ICF-C1T Speaker Replacement, Speaker: 手順 1、 2の画像 2
    • Using a Phillips #00 screwdriver, remove the four 14mm screws from the underside of the device.
    • Be sure that the device is unplugged and the battery has been removed before tampering with the device.
  2. Sony ICF-C1T Speaker Replacement: 手順 2、 1の画像 1
    • Using the opening tool, gently pry the top portion from the side section of your device.
  3. Sony ICF-C1T Speaker Replacement: 手順 3、 2の画像 1 Sony ICF-C1T Speaker Replacement: 手順 3、 2の画像 2
    • Gently pull the top of the clock away from the rest of the device.
    • Be careful when tugging on this piece of the clock. The clock display is located directly inside the front face and is connected by multiple wires.
  4. Sony ICF-C1T Speaker Replacement: 手順 4、 2の画像 1 Sony ICF-C1T Speaker Replacement: 手順 4、 2の画像 2
    • Using the Phillips #00 screwdriver, remove the two 14mm screws from the top of the motherboard.
    • Be careful to avoid the sharp pieces on the motherboard when handling the device.
  5. Sony ICF-C1T Speaker Replacement: 手順 5、 3の画像 1 Sony ICF-C1T Speaker Replacement: 手順 5、 3の画像 2 Sony ICF-C1T Speaker Replacement: 手順 5、 3の画像 3
    • Remove the Phillips #00 screw from the bottom of the white and blue box.
    • Remove the Phillips #00 screw from behind the white and blue box.
    • After unscrewing the white box, gently pull it out. This will allow for more room to access the speaker.
  6. Sony ICF-C1T Speaker Replacement: 手順 6、 1の画像 1
    • To separate the motherboard completely, you can cut the red and black wires that are attached to the speaker. This will allow you to access the speaker fully.
    • Use caution when tampering with the wires and sharp parts of the device.
  7. Sony ICF-C1T Speaker Replacement: 手順 7、 2の画像 1 Sony ICF-C1T Speaker Replacement: 手順 7、 2の画像 2
    • Use the plastic opening tool and the spudger to separate the speaker from the device by tracing its outline and loosening the glue.
    • Do this step gently as to not damage the device or cause harm to yourself.
    • When reassembling the device, you will need to use glue to place the new speaker back in its place.
    • It would be wise to test the device after reconnecting wires, before screwing and gluing the parts back together.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Megan
メンバー登録日: 01/30/15
275 ポイント
2のガイドは作成済み
チーム
University of Kentucky Louisville, Team 1-5, Rountree Winter 2015 University of Kentucky Louisville, Team 1-5, Rountree Winter 2015人のメンバー
LOUISVILLE-ROUNTREE-W15S1G5
3 メンバー
5のガイドは作成済み
コメント 1 件
can I connect aux out port to speaker?
Dong-Hwan Shin - 返信
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 7
過去 30 日: 14
今までの合計 2,572
