メインコンテンツにスキップ
Sony Handycam HDR-CX675 Shutter Assembly Replacement
必要な工具と部品
  1. Sony Handycam HDR-CX675 Shutter Assembly Replacement, Camera Shell: 手順 1、 1の画像 1
    • The battery should be removed and oriented upwards.
  2. Sony Handycam HDR-CX675 Shutter Assembly Replacement: 手順 2、 1の画像 1
    • Remove the side 4.5 mm JIS #00 screw using JIS Screwdriver
    • Remove the 5.5 mm JIS #00 screw.
  3. Sony Handycam HDR-CX675 Shutter Assembly Replacement: 手順 3、 2の画像 1 Sony Handycam HDR-CX675 Shutter Assembly Replacement: 手順 3、 2の画像 2
    • Gently pry the plastic case surrounding the start/stop button free by using the blue plastic opening tools.
    • Remove the casing using your thumb and index finger.
  4. Sony Handycam HDR-CX675 Shutter Assembly Replacement: 手順 4、 1の画像 1
    • Turn the camera around and flip open the LCD screen to expose the side panel.
    • Remove the 5.5mm #00 screw using the J00 head screwdriver.
  5. Sony Handycam HDR-CX675 Shutter Assembly Replacement: 手順 5、 1の画像 1
    • Turn the camera to the handgrip side and unscrew two of the 5.5mm JIS #00 head screws using the JIS #00 head screwdriver.
  6. Sony Handycam HDR-CX675 Shutter Assembly Replacement: 手順 6、 1の画像 1
    • Remove the two 5.5mm JIS #00 screws with the bottom of the camera facing up.
  7. Sony Handycam HDR-CX675 Shutter Assembly Replacement: 手順 7、 1の画像 1
    • Turn the camera around in a way that the bottom of the camera is facing you.
    • Use the blue opening tool to gently remove the camera shell off of the camera.
  8. Sony Handycam HDR-CX675 Shutter Assembly Replacement, Lens Cover Panel: 手順 8、 1の画像 1
    • Using the blue plastic opener smoothly to take the camera shell off.
  9. Sony Handycam HDR-CX675 Shutter Assembly Replacement: 手順 9、 2の画像 1 Sony Handycam HDR-CX675 Shutter Assembly Replacement: 手順 9、 2の画像 2
    • Let the lens of the camera be pointed to your left.
    • Keep holding the camera with your right hand then gently remove the lens cover panel with your left hand.
  10. Sony Handycam HDR-CX675 Shutter Assembly Replacement, Shutter Assembly: 手順 10、 1の画像 1
    • Place the camera on its lens and keep the LCD screen open and pointed to your right.
    • Remove the 5.5mm JIS #00 screws from the hinge of the camera.
  11. Sony Handycam HDR-CX675 Shutter Assembly Replacement: 手順 11、 2の画像 1 Sony Handycam HDR-CX675 Shutter Assembly Replacement: 手順 11、 2の画像 2
    • Hold the camera with your left hand, and gently remove the shutter assembly part.
  12. Sony Handycam HDR-CX675 Shutter Assembly Replacement: 手順 12、 1の画像 1
    この手順で使用する道具:
    購入する
    • Hold the camera that the bottom is upwards and lens pointed to your left hand.
    • By the metal tweezers, remove the white wire that is connecting the shutter assembly and motherboard
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Mohamed Nazer
メンバー登録日: 02/15/17
403 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team 8-2, Eyestone Spring 2017 USF Tampa, Team 8-2, Eyestone Spring 2017人のメンバー
USFT-EYESTONE-S17S8G2
3 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 21
今までの合計 732
