メインコンテンツにスキップ
Sony Handycam HDR-CX675 Lens Cover Panel Replacement
必要な工具と部品
  1. Sony Handycam HDR-CX675 Lens Cover Panel Replacement, Camera Shell: 手順 1、 1の画像 1
    • The battery should be removed and oriented upwards.
  2. Sony Handycam HDR-CX675 Lens Cover Panel Replacement: 手順 2、 1の画像 1
    • Remove the side 4.5 mm JIS #00 screw using JIS Screwdriver
    • Remove the 5.5 mm JIS #00 screw.
  3. Sony Handycam HDR-CX675 Lens Cover Panel Replacement: 手順 3、 2の画像 1 Sony Handycam HDR-CX675 Lens Cover Panel Replacement: 手順 3、 2の画像 2
    • Gently pry the plastic case surrounding the start/stop button free by using the blue plastic opening tools.
    • Remove the casing using your thumb and index finger.
  4. Sony Handycam HDR-CX675 Lens Cover Panel Replacement: 手順 4、 1の画像 1
    • Turn the camera around and flip open the LCD screen to expose the side panel.
    • Remove the 5.5mm #00 screw using the J00 head screwdriver.
  5. Sony Handycam HDR-CX675 Lens Cover Panel Replacement: 手順 5、 1の画像 1
    • Turn the camera to the handgrip side and unscrew two of the 5.5mm JIS #00 head screws using the JIS #00 head screwdriver.
  6. Sony Handycam HDR-CX675 Lens Cover Panel Replacement: 手順 6、 1の画像 1
    • Remove the two 5.5mm JIS #00 screws with the bottom of the camera facing up.
  7. Sony Handycam HDR-CX675 Lens Cover Panel Replacement: 手順 7、 1の画像 1
    • Turn the camera around in a way that the bottom of the camera is facing you.
    • Use the blue opening tool to gently remove the camera shell off of the camera.
  8. Sony Handycam HDR-CX675 Lens Cover Panel Replacement, Lens Cover Panel: 手順 8、 1の画像 1
    • Using the blue plastic opener smoothly to take the camera shell off.
  9. Sony Handycam HDR-CX675 Lens Cover Panel Replacement: 手順 9、 2の画像 1 Sony Handycam HDR-CX675 Lens Cover Panel Replacement: 手順 9、 2の画像 2
    • Let the lens of the camera be pointed to your left.
    • Keep holding the camera with your right hand then gently remove the lens cover panel with your left hand.
終わりに
作成者
2人の作成者と共同で作成されました。
Laith Al Hinai
メンバー登録日: 02/15/17
161 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team 8-2, Eyestone Spring 2017 USF Tampa, Team 8-2, Eyestone Spring 2017人のメンバー
USFT-EYESTONE-S17S8G2
3 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 15
今までの合計 814
