メインコンテンツにスキップ
Sony Handycam HDR-CX580V Recording Button Replacement
必要な工具と部品
  1. Sony Handycam HDR-CX580V Recording Button Replacement, Battery: 手順 1、 1の画像 1
    • Locate the slider labeled "BATT" and pull it back from the battery with your thumb.
  2. Sony Handycam HDR-CX580V Recording Button Replacement: 手順 2、 1の画像 1
    • At this point, you should be able to remove the battery by simply lifting it from the camera.
    • The camera provided for guide-creation did not include a battery. However, the battery position should be the same.
  3. Sony Handycam HDR-CX580V Recording Button Replacement, Recording Button: 手順 3、 3の画像 1 Sony Handycam HDR-CX580V Recording Button Replacement, Recording Button: 手順 3、 3の画像 2 Sony Handycam HDR-CX580V Recording Button Replacement, Recording Button: 手順 3、 3の画像 3
    • Use the Phillips #00 head to remove the following 5.5mm screws on the left-hand side.
  4. Sony Handycam HDR-CX580V Recording Button Replacement: 手順 4、 1の画像 1
    • Use the Phillips #00 head to remove the following 5.5mm screws on the empty battery socket.
  5. Sony Handycam HDR-CX580V Recording Button Replacement: 手順 5、 1の画像 1
    • Use the Phillips #00 head to remove the following 5.5mm screws on the bottom.
  6. Sony Handycam HDR-CX580V Recording Button Replacement: 手順 6、 1の画像 1
    • Fold back the hinging panel on the top of the camera located near the lens.
    • Use the Phillips #00 head to remove the following 5.5mm screws on the top under the hinging panel.
  7. Sony Handycam HDR-CX580V Recording Button Replacement: 手順 7、 2の画像 1 Sony Handycam HDR-CX580V Recording Button Replacement: 手順 7、 2の画像 2
    • Slide back the cover for the DC and A/V ports on the right-hand side.
    • Use the Phillips #00 head to remove the following 5.5mm screws underneath the cover and on the right-hand side.
  8. Sony Handycam HDR-CX580V Recording Button Replacement: 手順 8、 1の画像 1
    • Use the plastic opener tool to loosen the casing on the bottom and the right-hand side.
    • At this point, the right-hand side should simply come off, although it will still be connected with internal wiring.
    • Be delicate with the wiring still attached to the side casing until you have access to removing them later.
  9. Sony Handycam HDR-CX580V Recording Button Replacement: 手順 9、 3の画像 1 Sony Handycam HDR-CX580V Recording Button Replacement: 手順 9、 3の画像 2 Sony Handycam HDR-CX580V Recording Button Replacement: 手順 9、 3の画像 3
    • Carefully remove the bottom casing with your fingers.
    • Be careful not to loose the small metal stand-mount pieces that lay underneath the casing.
  10. Sony Handycam HDR-CX580V Recording Button Replacement: 手順 10、 1の画像 1
    • Look at the right side of the camera (the side with the recording button) while holding back the detached casing.
    • Use the Phillips #00 head to remove the following 5.5mm screws near the recording button.
  11. Sony Handycam HDR-CX580V Recording Button Replacement: 手順 11、 1の画像 1
    • Use the curved tweezers to carefully detach the blue ribbon cable connector from the body of the camera.
    • The recording button and its blue ribbon cable connector should become detached from the body, but remain connected to the top casing.
  12. Sony Handycam HDR-CX580V Recording Button Replacement: 手順 12、 2の画像 1 Sony Handycam HDR-CX580V Recording Button Replacement: 手順 12、 2の画像 2
    • Pull off the top casing by lightly grabbing either side and pulling towards the back of the camera.
  13. Sony Handycam HDR-CX580V Recording Button Replacement: 手順 13、 1の画像 1
    • Use the Phillips #00 head to remove the following 5.5mm screws on the inside of the top casing.
  14. Sony Handycam HDR-CX580V Recording Button Replacement: 手順 14、 1の画像 1
    • Carefully remove the metal frame from the top casing.
  15. Sony Handycam HDR-CX580V Recording Button Replacement: 手順 15、 1の画像 1
    • You are now free to remove the recording button, as well as its connection strip.
終わりに
作成者
2人の作成者と共同で作成されました。
Derek Fritz
メンバー登録日: 03/21/17
378 ポイント
3のガイドは作成済み
チーム
Texas Tech, Team S46-G5, Bennett Spring 2017 Texas Tech, Team S46-G5, Bennett Spring 2017人のメンバー
TTU-BENNETT-S17S46G5
4 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 8
今までの合計 408
