This guide will help to locate and remove the motherboard for replacement. This will involve removing a significant portion of the camera and wiring.
At this point, you should be able to remove the battery by simply lifting it from the camera.
The camera provided for guide-creation did not include a battery. However, the battery position should be the same.
Use the plastic opener tool to loosen the casing on the bottom and the right-hand side.
At this point, the right-hand side should simply come off, although it will still be connected with internal wiring.
Be delicate with the wiring still attached to the side casing until you have access to removing them later.
Look at the right side of the camera (the side with the recording button) while holding back the detached casing.
Use the Phillips #00 head to remove the following 5.5mm screws near the recording button.
Use the curved tweezers to carefully detach the blue ribbon cable connector from the body of the camera.
The recording button and its blue ribbon cable connector should become detached from the body, but remain connected to the top casing.
Carefully pull the lens cover and shutter assembly off of the front of the camera.
Do not pull the the wires out too strongly. Be sure to remove them from their base where they attach to the camera's body.
Hold the camera so you can see the motherboard on its bottom.
With a pair of straight tweezers, carefully remove the hanging panel by the following bundled cable connectors and ribbon cable connector attached to the motherboard.
At this point, the side panel that has been hanging should now be removed and placed to the side.
Use the Phillips #00 head to remove the 5.5mm screw inside the metal casing.
This screw may be hidden under the black strip inside the camera's body. If so, carefully move it aside with the pair of straight tweezers.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
1つの手順
全ガイド
小サイズ - 600px
中サイズ - 800px
大サイズ - 1200px
プレビュー
