はじめに
In this guide you will work through the process of removing the lens from the camera. This involves removing many moving parts of the camera, as well as some wiring and large amount of casing. This will, however, allow you to clean the lens more directly.
必要な工具と部品
Use the Phillips #00 head to remove the following 5.5mm screws on the left-hand side.
もう少しです!
終わりに
