メインコンテンツにスキップ
Sony Handycam FDR-AX33 Eyepiece Replacement
必要な工具と部品
  1. Sony Handycam FDR-AX33 Eyepiece Replacement, Panel: 手順 1、 2の画像 1 Sony Handycam FDR-AX33 Eyepiece Replacement, Panel: 手順 1、 2の画像 2
    • Remove the battery by pushing the latch towards the body of the camera. Push the battery down and pull it out.
    • Remove the six black 4 mm Phillips #00 screws from the bottom panel of the camera.
    • Pull off the bottom panel. It may be difficult, but tugging on it shouldn't cause harm to yourself or the device.
    • Be sure to un-velcro the handle strap.
  2. Sony Handycam FDR-AX33 Eyepiece Replacement: 手順 2、 3の画像 1 Sony Handycam FDR-AX33 Eyepiece Replacement: 手順 2、 3の画像 2 Sony Handycam FDR-AX33 Eyepiece Replacement: 手順 2、 3の画像 3
    • Remove the 3 mm Phillips #00 screw from the bottom of the camera.
    • Remove the 4 mm Phillips #00 screw from the right panel.
    • Pull the right panel off. Again, it might be difficult, but pulling hard shouldn't harm you or the camera.
    • You may have to use the opening tool to remove this panel.
  3. Sony Handycam FDR-AX33 Eyepiece Replacement: 手順 3、 2の画像 1 Sony Handycam FDR-AX33 Eyepiece Replacement: 手順 3、 2の画像 2
    • Remove the two 4 mm Phillips #00 screws from the top right corner of the camera.
    • Remove the 4 mm Phillips #00 screw from in front of the flash mount.
  4. Sony Handycam FDR-AX33 Eyepiece Replacement: 手順 4、 2の画像 1 Sony Handycam FDR-AX33 Eyepiece Replacement: 手順 4、 2の画像 2
    • Remove the 3 mm Phillips #00 screw from below the right side of the battery slot.
    • Remove the black 5 mm Phillips #00 screw from the top of the battery slot.
  5. Sony Handycam FDR-AX33 Eyepiece Replacement: 手順 5、 3の画像 1 Sony Handycam FDR-AX33 Eyepiece Replacement: 手順 5、 3の画像 2 Sony Handycam FDR-AX33 Eyepiece Replacement: 手順 5、 3の画像 3
    • Remove the three 4 mm Phillips #00 screws from the left panel underneath the display screen.
    • You’ll need to extend the eyepiece by pulling it out from the body of the camera.
    • Pull the top panel off of the device with the iFixit opening tool.
  6. Sony Handycam FDR-AX33 Eyepiece Replacement: 手順 6、 3の画像 1 Sony Handycam FDR-AX33 Eyepiece Replacement: 手順 6、 3の画像 2 Sony Handycam FDR-AX33 Eyepiece Replacement: 手順 6、 3の画像 3
    • Remove the top and bottom 4 mm Phillips #00 screws from the display screen hinge.
    • Use the iFixit opening tool to remove the screen hinge.
  7. Sony Handycam FDR-AX33 Eyepiece Replacement: 手順 7、 2の画像 1 Sony Handycam FDR-AX33 Eyepiece Replacement: 手順 7、 2の画像 2
    • Remove the 3 mm Phillips #00 screw from between the eyepiece and the panel directly to the right of the battery slot.
    • Angle the eyepiece up to reach the screw with the screwdriver.
    • Take the panel directly to the right of the battery slot off of the camera.
  8. Sony Handycam FDR-AX33 Eyepiece Replacement: 手順 8、 3の画像 1 Sony Handycam FDR-AX33 Eyepiece Replacement: 手順 8、 3の画像 2 Sony Handycam FDR-AX33 Eyepiece Replacement: 手順 8、 3の画像 3
    • Remove the 4 mm Phillips #00 screw above and to the right of the battery slot.
    • Pry the left panel out at an angle by pushing the plastic slat between the battery slot and the eyepiece.
    • Wiggle the left panel and pull it out gently.
    • The left panel can be hard to remove so make sure to apply a good amount of force, but be cautious to not harm yourself or the device.
  9. Sony Handycam FDR-AX33 Eyepiece Replacement, Zoom, Photo, and Record Button: 手順 9、 3の画像 1 Sony Handycam FDR-AX33 Eyepiece Replacement, Zoom, Photo, and Record Button: 手順 9、 3の画像 2 Sony Handycam FDR-AX33 Eyepiece Replacement, Zoom, Photo, and Record Button: 手順 9、 3の画像 3
    • Remove the two 3 mm Phillips screws directly in front of the zoom button.
    • Slide the blue copper PCB out of the connector.
  10. Sony Handycam FDR-AX33 Eyepiece Replacement: 手順 10、 2の画像 1 Sony Handycam FDR-AX33 Eyepiece Replacement: 手順 10、 2の画像 2
    • Unclip the black plastic piece from behind the record button in order to remove the photo, record, and zoom buttons.
    • Use the black nylon spudger to remove the record button.
  11. Sony Handycam FDR-AX33 Eyepiece Replacement, Eyepiece: 手順 11、 1の画像 1
    • Remove the two 3 mm Phillips #00 screws in front of the two screws you removed in the previous step.
    • Remove the 3 mm Phillips #00 screw to the right of the eyepiece.
    • Remove the 4 mm Phillips #00 screw to the left of the eyepiece.
  12. Sony Handycam FDR-AX33 Eyepiece Replacement: 手順 12、 2の画像 1 Sony Handycam FDR-AX33 Eyepiece Replacement: 手順 12、 2の画像 2
    • Pull up on the copper PCB wire attaching the eyepiece to the body of the camera.
    • Copper PCB wire breaks very easily, use extreme caution when removing it. Be sure not to bend or twist the PCB wire.
    • Remove the eyepiece from the body of the camera.
終わりに
作成者
3人の作成者と共同で作成されました。
Lee Conway
メンバー登録日: 01/24/19
184 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team S18-G2, White Winter 2019 Cal Poly, Team S18-G2, White Winter 2019人のメンバー
CPSU-WHITE-W19S18G2
4 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 12
今までの合計 596
