Place device on left side with lens facing right.
Using the screwdriver, unscrew the left middle screw.
Open the "DC IN" tab.
Second screw is revealed.
Unscrew this screw.
Turn device onto it's top with the lens facing right.
Unscrew the top left and top right screws.
Right side casing is now free.
Using your fingers, lift the HDD by it's right end, pivoting on it's left end.
HDD ribbon wire is now exposed.
Using the screwdriver, unscrew the top two black 3mm Philips screws.
Lift out the grey tray, being careful when feeding the large ribbon wire though the slot.
Using the black pointed spudger, carefully pop op the latch on the large ribbon wire's port.
Set large ribbon wire aside.
Using the blunt tweezers, unplug the red and black wires.
Using the blunt tweezers, unplug the small ribbon wire.
On the left side of the device, unscrew the top 2 3mm Philips screws.
The top of the device is now free.
With the top of the device in hand, remove the 4 visible 3mm Philips screws.
Remove the frame by lifting away.
The speaker is the object on the right with a ribbon wire connecting to it.
Remove the broken speaker with your fingers.
Replace with new speaker.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
