はじめに
Can't view your pictures anymore after dropping your camera, and breaking the screen ? This guide will help you replace your LCD screen, so you can enjoy your camera once again.
必要な工具と部品
この手順で使用する道具:Tweezers$4.99
Using the blunt tweezers, unplug the red and black wire by gently pulling out and away.
Unplug the small ribbon wire.
To reassemble your device, follow these instructions in reverse order in addition to the HDD Replacement guide.
2 の人々がこのガイドを完成させました。
2 件のコメント
Hello, so i have my friends handycam, sony dcr sr68 and i don't know what happened to it but the screen doesn't close at all, it stays open which makes it stay turned on. When i try to close it it just opens right back up. I do not know how to fix it at all since I don't know much about camera's, but i want to return the camera back to them as it was originally.
Hello did you find a solution for this? I have the same problem
