メインコンテンツにスキップ
Sony Handycam DCR-SR68 HDD Replacement
必要な工具と部品
  1. Sony Handycam DCR-SR68 HDD Replacement, HDD: 手順 1、 1の画像 1
    この手順で使用する道具:
    Anti-Static Wrist Strap
    $7.95
    • Wash and dry your hands, then put on a properly grounded anti-static wrist strap, before handling internal electronic components. To ground the wrist strap, attach it to the metal chassis of a plugged-in three prong power supply, of a computer for example.
    • Unfasten the hand strap.
    • Remove the battery.
  2. Sony Handycam DCR-SR68 HDD Replacement: 手順 2、 2の画像 1 Sony Handycam DCR-SR68 HDD Replacement: 手順 2、 2の画像 2
    • Place device on left side with front lens facing right.
    • Using a JIS size #00 precision Phillips screwdriver, unscrew the left middle 3mm Phillips screw.
    • Open the "DC IN" plastic tab (Second 3mm Phillips screw is revealed).
    • Unscrew the second 3mm Phillips screw.
  3. Sony Handycam DCR-SR68 HDD Replacement: 手順 3、 1の画像 1
    • Turn device over onto its top with the front lens facing right.
    • Unscrew the top left and top right 3mm Philips screws.
    • The right side case panel is now unfastened (the case panel facing up in the photo).
  4. Sony Handycam DCR-SR68 HDD Replacement: 手順 4、 2の画像 1 Sony Handycam DCR-SR68 HDD Replacement: 手順 4、 2の画像 2
    • Remove the right side case panel by pulling up.
    • The Hard Drive (HDD) is now revealed.
  5. Sony Handycam DCR-SR68 HDD Replacement: 手順 5、 3の画像 1 Sony Handycam DCR-SR68 HDD Replacement: 手順 5、 3の画像 2 Sony Handycam DCR-SR68 HDD Replacement: 手順 5、 3の画像 3
    • Using your fingers, lift the HDD from its right end, pivoting on its left end.
    • The HDD ribbon wire is now exposed.
  6. Sony Handycam DCR-SR68 HDD Replacement: 手順 6、 2の画像 1 Sony Handycam DCR-SR68 HDD Replacement: 手順 6、 2の画像 2
    • While securely holding the HDD in your left hand, use the soft pad of your right hand fingers to gently pull the ribbon wire out of its socket, toward your right.
    • The HDD is now free from the device.
    • Replace HDD.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Greg Thorburn
メンバー登録日: 01/06/16
365 ポイント
1ガイドが承認済み
チーム
Eastern Washington University, Team 2-5, Andersen Winter 2016 Eastern Washington University, Team 2-5, Andersen Winter 2016人のメンバー
EWU-ANDERSEN-W16S2G5
5 メンバー
13のガイドは作成済み
2件のガイドコメント
Dónde puedo adquirir ese HDD?
Juan Jose Rojas - 返信
Buenas, tardes. Necesito ese HDD. Dónde lo puedo conseguir.Soy de Perú. Gracias.
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 19
今までの合計 1,185
