メインコンテンツにスキップ
Sony Handycam DCR-SR42 LCD Screen Replacement
必要な工具と部品
  1. Sony Handycam DCR-SR42 LCD Screen Replacement, Hard Drive: 手順 1、 2の画像 1 Sony Handycam DCR-SR42 LCD Screen Replacement, Hard Drive: 手順 1、 2の画像 2
    • Remove the battery, and use the Phillips #00 precision screwdriver to then remove the three 3mm Phillips #00 screws under the battery.
    • Wait 1 hour after removing the battery before continuing to disassemble the camera.
  2. Sony Handycam DCR-SR42 LCD Screen Replacement: 手順 2、 1の画像 1
    • Remove the three 3mm #00 Phillips screws on the bottom of the camera.
  3. Sony Handycam DCR-SR42 LCD Screen Replacement: 手順 3、 1の画像 1
    • Remove the three 3mm Phillips #00 screws on the side of the camera.
    • Remove the 4mm Phillips #00 screw under the AV port cover.
  4. Sony Handycam DCR-SR42 LCD Screen Replacement: 手順 4、 2の画像 1 Sony Handycam DCR-SR42 LCD Screen Replacement: 手順 4、 2の画像 2
    • Gently pull the black plastic hard drive cover away from the body of the camera. This will expose the hard drive.
    • Even with all the screws removed, this part will require some force to remove.
  5. Sony Handycam DCR-SR42 LCD Screen Replacement: 手順 5、 2の画像 1 Sony Handycam DCR-SR42 LCD Screen Replacement: 手順 5、 2の画像 2
    • Lift the hard drive out of the camera by grasping the grey rubber mounting brackets and pulling them upwards.
    • The hard drive is attached to the flex cable. Remove the hard drive slowly to prevent the flex cable from being damaged.
  6. Sony Handycam DCR-SR42 LCD Screen Replacement: 手順 6、 1の画像 1
    • Remove the rubber mounting brackets by pulling them off the hard drive.
  7. Sony Handycam DCR-SR42 LCD Screen Replacement: 手順 7、 1の画像 1
    • Carefully unplug the flex cable from the hard drive.
  8. Sony Handycam DCR-SR42 LCD Screen Replacement, Internal Components: 手順 8、 2の画像 1 Sony Handycam DCR-SR42 LCD Screen Replacement, Internal Components: 手順 8、 2の画像 2
    • Remove the four 3mm Phillips #00 screws from under the hard drive.
  9. Sony Handycam DCR-SR42 LCD Screen Replacement: 手順 9、 3の画像 1 Sony Handycam DCR-SR42 LCD Screen Replacement: 手順 9、 3の画像 2 Sony Handycam DCR-SR42 LCD Screen Replacement: 手順 9、 3の画像 3
    • Press in on the two tabs as shown and lift the metal plate up and off the camera.
  10. Sony Handycam DCR-SR42 LCD Screen Replacement: 手順 10、 3の画像 1 Sony Handycam DCR-SR42 LCD Screen Replacement: 手順 10、 3の画像 2 Sony Handycam DCR-SR42 LCD Screen Replacement: 手順 10、 3の画像 3
    • Remove the two 4mm Phillips #00 screws from the underside of the camera.
    • Remove the 2 mm Phillips #00 screw from the screen hinge.
    • Remove the two 6mm Philips #00 screws from the side
  11. Sony Handycam DCR-SR42 LCD Screen Replacement: 手順 11、 3の画像 1 Sony Handycam DCR-SR42 LCD Screen Replacement: 手順 11、 3の画像 2 Sony Handycam DCR-SR42 LCD Screen Replacement: 手順 11、 3の画像 3
    • Use the plastic opening tool to remove the plastic cover from the top of the camera.
    • Remove the two 3mm Phillips #00 screws from underneath the plastic cover.
  12. Sony Handycam DCR-SR42 LCD Screen Replacement: 手順 12、 2の画像 1 Sony Handycam DCR-SR42 LCD Screen Replacement: 手順 12、 2の画像 2
    • Remove the second plastic cover from the top of the camera.
    • Remove the 4mm Phillips #00 screw from underneath the cover.
  13. Sony Handycam DCR-SR42 LCD Screen Replacement: 手順 13、 2の画像 1 Sony Handycam DCR-SR42 LCD Screen Replacement: 手順 13、 2の画像 2
    • Carefully pry the screen assembly apart from the main body of the camera.
    • Unplug the flex cable from the screen assembly.
  14. Sony Handycam DCR-SR42 LCD Screen Replacement, Flex Cable: 手順 14、 1の画像 1
    • Remove the 5 3mm Phillips #00 Screws from the screen assembly.
  15. Sony Handycam DCR-SR42 LCD Screen Replacement: 手順 15、 3の画像 1 Sony Handycam DCR-SR42 LCD Screen Replacement: 手順 15、 3の画像 2 Sony Handycam DCR-SR42 LCD Screen Replacement: 手順 15、 3の画像 3
    • Carefully lift up the sound chip and peel the flex cable off the screen case.
    • Lift off the plastic bracket from the hinge.
  16. Sony Handycam DCR-SR42 LCD Screen Replacement: 手順 16、 2の画像 1 Sony Handycam DCR-SR42 LCD Screen Replacement: 手順 16、 2の画像 2
    • Remove the screen from the plastic case by pulling the flex cable and sound chip through the hole in the case.
  17. Sony Handycam DCR-SR42 LCD Screen Replacement: 手順 17、 1の画像 1
    • Turn the hinge sideways and remove the two 4mm Phillips #00 screws from the side of the screen.
  18. Sony Handycam DCR-SR42 LCD Screen Replacement: 手順 18、 3の画像 1 Sony Handycam DCR-SR42 LCD Screen Replacement: 手順 18、 3の画像 2 Sony Handycam DCR-SR42 LCD Screen Replacement: 手順 18、 3の画像 3
    • Use the plastic opening tool to remove the plastic hinge covers and expose the metal hinge.
    • Unwrap the flex cable from around the hinge.
  19. Sony Handycam DCR-SR42 LCD Screen Replacement: 手順 19、 2の画像 1 Sony Handycam DCR-SR42 LCD Screen Replacement: 手順 19、 2の画像 2
    • Use the plastic opening tool to open the screen case.
  20. Sony Handycam DCR-SR42 LCD Screen Replacement: 手順 20、 2の画像 1 Sony Handycam DCR-SR42 LCD Screen Replacement: 手順 20、 2の画像 2
    • Unplug the flex cable from the sound chip.
    • Unplug the flex cable from the screen chip.
  21. Sony Handycam DCR-SR42 LCD Screen Replacement, LCD Screen: 手順 21、 1の画像 1
    • Unscrew the 2mm Phillips #00 screw from the screen chip.
  22. Sony Handycam DCR-SR42 LCD Screen Replacement: 手順 22、 2の画像 1 Sony Handycam DCR-SR42 LCD Screen Replacement: 手順 22、 2の画像 2
    • Remove the LCD screen and chip from the plastic case.
    • Separate the screen from the chip.
  23. Sony Handycam DCR-SR42 LCD Screen Replacement: 手順 23、 2の画像 1 Sony Handycam DCR-SR42 LCD Screen Replacement: 手順 23、 2の画像 2
    • Unplug the screen cable from the screen chip.
終わりに
6 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Dan Muller
メンバー登録日: 03/23/15
1,128 ポイント
5のガイドは作成済み
チーム
Baylor, Team 7-13, Williams Spring 2015 Baylor, Team 7-13, Williams Spring 2015人のメンバー
BU-WILLIAMS-S15S7G13
4 メンバー
10のガイドは作成済み
3 件のコメント
Good narration,but very sofia fixated parts and needs to handle gently and carefully.not an easy
dvsureshkreddy - 返信
What’s a link to a replacement screen?
Rick Astely - 返信
Had a loose hinge on the identical DCR-SR52 (screen was flopping around at the smallest movement), I could not have fixed it without this guide, thanks a lot.
IPaul 6253 - 返信
コメントを追加
統計データ:
過去 24時間: 7
過去 7 日: 19
過去 30 日: 56
今までの合計 6,196
