メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
はじめに
Prerequisite only
パーツ
パーツは指定されていません。
  1. Remove the battery, and use the Phillips #00 precision screwdriver to then remove the three 3mm Phillips #00 screws under the battery. Wait 1 hour after removing the battery before continuing to disassemble the camera.
    • Remove the battery, and use the Phillips #00 precision screwdriver to then remove the three 3mm Phillips #00 screws under the battery.
    • Wait 1 hour after removing the battery before continuing to disassemble the camera.
  2. Remove the three 3mm #00 Phillips screws on the bottom of the camera.
    • Remove the three 3mm #00 Phillips screws on the bottom of the camera.
  3. Remove the three 3mm Phillips #00 screws on the side of the camera.
    • Remove the three 3mm Phillips #00 screws on the side of the camera.
    • Remove the 4mm Phillips #00 screw under the AV port cover.
  4. Gently pull the black plastic hard drive cover away from the body of the camera. This will expose the hard drive. Even with all the screws removed, this part will require some force to remove.
    • Gently pull the black plastic hard drive cover away from the body of the camera. This will expose the hard drive.
    • Even with all the screws removed, this part will require some force to remove.
  5. Lift the hard drive out of the camera by grasping the grey rubber mounting brackets and pulling them upwards. The hard drive is attached to the flex cable. Remove the hard drive slowly to prevent the flex cable from being damaged.
    • Lift the hard drive out of the camera by grasping the grey rubber mounting brackets and pulling them upwards.
    • The hard drive is attached to the flex cable. Remove the hard drive slowly to prevent the flex cable from being damaged.
  6. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  7. Remove the rubber mounting brackets by pulling them off the hard drive.
    • Remove the rubber mounting brackets by pulling them off the hard drive.
  8. Carefully unplug the flex cable from the hard drive.
    • Carefully unplug the flex cable from the hard drive.
  9. Remove the four 3mm Phillips #00 screws from under the hard drive. Remove the four 3mm Phillips #00 screws from under the hard drive.
    • Remove the four 3mm Phillips #00 screws from under the hard drive.
  10. Press in on the two tabs as shown and lift the metal plate up and off the camera. Even with all the screws removed, this part will require some force to remove. Even with all the screws removed, this part will require some force to remove.
    • Press in on the two tabs as shown and lift the metal plate up and off the camera.
  11. Remove the two 4mm Phillips #00 screws from the underside of the camera. Remove the 2 mm Phillips #00 screw from the screen hinge. Remove the 2 mm Phillips #00 screw from the screen hinge.
    • Remove the two 4mm Phillips #00 screws from the underside of the camera.
    • Remove the 2 mm Phillips #00 screw from the screen hinge.
  12. Use the plastic opening tool to remove the plastic cover from the top of the camera. Remove the two 3mm Phillips #00 screws from underneath the plastic cover. Remove the two 3mm Phillips #00 screws from underneath the plastic cover.
    • Use the plastic opening tool to remove the plastic cover from the top of the camera.
    • Remove the two 3mm Phillips #00 screws from underneath the plastic cover.
  13. Remove the second plastic cover from the top of the camera. Remove the 4mm Phillips #00 screw from underneath the cover.
    • Remove the second plastic cover from the top of the camera.
    • Remove the 4mm Phillips #00 screw from underneath the cover.
  14. Carefully pry the screen assembly apart from the main body of the camera. Unplug the flex cable from the screen assembly.
    • Carefully pry the screen assembly apart from the main body of the camera.
    • Unplug the flex cable from the screen assembly.
終わりに
Dan Muller
メンバー登録日: 2015年03月23日
882 ポイント
5のガイドは作成済み
チーム
Baylor, Team 7-13, Williams Spring 2015 Baylor, Team 7-13, Williams Spring 2015人のメンバー
BU-WILLIAMS-S15S7G13
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 31
