メインコンテンツにスキップ
Sony Handycam DCR-SR42 Flex Cable Replacement
必要な工具と部品
  1. Sony Handycam DCR-SR42 Flex Cable Replacement, Hard Drive: 手順 1、 2の画像 1 Sony Handycam DCR-SR42 Flex Cable Replacement, Hard Drive: 手順 1、 2の画像 2
    • Remove the battery, and use the Phillips #00 precision screwdriver to then remove the three 3mm Phillips #00 screws under the battery.
    • Wait 1 hour after removing the battery before continuing to disassemble the camera.
  2. Sony Handycam DCR-SR42 Flex Cable Replacement: 手順 2、 1の画像 1
    • Remove the three 3mm #00 Phillips screws on the bottom of the camera.
  3. Sony Handycam DCR-SR42 Flex Cable Replacement: 手順 3、 1の画像 1
    • Remove the three 3mm Phillips #00 screws on the side of the camera.
    • Remove the 4mm Phillips #00 screw under the AV port cover.
  4. Sony Handycam DCR-SR42 Flex Cable Replacement: 手順 4、 2の画像 1 Sony Handycam DCR-SR42 Flex Cable Replacement: 手順 4、 2の画像 2
    • Gently pull the black plastic hard drive cover away from the body of the camera. This will expose the hard drive.
    • Even with all the screws removed, this part will require some force to remove.
  5. Sony Handycam DCR-SR42 Flex Cable Replacement: 手順 5、 2の画像 1 Sony Handycam DCR-SR42 Flex Cable Replacement: 手順 5、 2の画像 2
    • Lift the hard drive out of the camera by grasping the grey rubber mounting brackets and pulling them upwards.
    • The hard drive is attached to the flex cable. Remove the hard drive slowly to prevent the flex cable from being damaged.
  6. Sony Handycam DCR-SR42 Flex Cable Replacement: 手順 6、 1の画像 1
    • Remove the rubber mounting brackets by pulling them off the hard drive.
  7. Sony Handycam DCR-SR42 Flex Cable Replacement: 手順 7、 1の画像 1
    • Carefully unplug the flex cable from the hard drive.
  8. Sony Handycam DCR-SR42 Flex Cable Replacement, Internal Components: 手順 8、 2の画像 1 Sony Handycam DCR-SR42 Flex Cable Replacement, Internal Components: 手順 8、 2の画像 2
    • Remove the four 3mm Phillips #00 screws from under the hard drive.
  9. Sony Handycam DCR-SR42 Flex Cable Replacement: 手順 9、 3の画像 1 Sony Handycam DCR-SR42 Flex Cable Replacement: 手順 9、 3の画像 2 Sony Handycam DCR-SR42 Flex Cable Replacement: 手順 9、 3の画像 3
    • Press in on the two tabs as shown and lift the metal plate up and off the camera.
  10. Sony Handycam DCR-SR42 Flex Cable Replacement: 手順 10、 3の画像 1 Sony Handycam DCR-SR42 Flex Cable Replacement: 手順 10、 3の画像 2 Sony Handycam DCR-SR42 Flex Cable Replacement: 手順 10、 3の画像 3
    • Remove the two 4mm Phillips #00 screws from the underside of the camera.
    • Remove the 2 mm Phillips #00 screw from the screen hinge.
  11. Sony Handycam DCR-SR42 Flex Cable Replacement: 手順 11、 3の画像 1 Sony Handycam DCR-SR42 Flex Cable Replacement: 手順 11、 3の画像 2 Sony Handycam DCR-SR42 Flex Cable Replacement: 手順 11、 3の画像 3
    • Use the plastic opening tool to remove the plastic cover from the top of the camera.
    • Remove the two 3mm Phillips #00 screws from underneath the plastic cover.
  12. Sony Handycam DCR-SR42 Flex Cable Replacement: 手順 12、 2の画像 1 Sony Handycam DCR-SR42 Flex Cable Replacement: 手順 12、 2の画像 2
    • Remove the second plastic cover from the top of the camera.
    • Remove the 4mm Phillips #00 screw from underneath the cover.
  13. Sony Handycam DCR-SR42 Flex Cable Replacement: 手順 13、 2の画像 1 Sony Handycam DCR-SR42 Flex Cable Replacement: 手順 13、 2の画像 2
    • Carefully pry the screen assembly apart from the main body of the camera.
    • Unplug the flex cable from the screen assembly.
  14. Sony Handycam DCR-SR42 Flex Cable Replacement, Flex Cable: 手順 14、 1の画像 1
    • Remove the 5 3mm Phillips #00 Screws from the screen assembly.
  15. Sony Handycam DCR-SR42 Flex Cable Replacement: 手順 15、 3の画像 1 Sony Handycam DCR-SR42 Flex Cable Replacement: 手順 15、 3の画像 2 Sony Handycam DCR-SR42 Flex Cable Replacement: 手順 15、 3の画像 3
    • Carefully lift up the sound chip and peel the flex cable off the screen case.
    • Lift off the plastic bracket from the hinge.
  16. Sony Handycam DCR-SR42 Flex Cable Replacement: 手順 16、 2の画像 1 Sony Handycam DCR-SR42 Flex Cable Replacement: 手順 16、 2の画像 2
    • Remove the screen from the plastic case by pulling the flex cable and sound chip through the hole in the case.
  17. Sony Handycam DCR-SR42 Flex Cable Replacement: 手順 17、 1の画像 1
    • Turn the hinge sideways and remove the two 4mm Phillips #00 screws from the side of the screen.
  18. Sony Handycam DCR-SR42 Flex Cable Replacement: 手順 18、 3の画像 1 Sony Handycam DCR-SR42 Flex Cable Replacement: 手順 18、 3の画像 2 Sony Handycam DCR-SR42 Flex Cable Replacement: 手順 18、 3の画像 3
    • Use the plastic opening tool to remove the plastic hinge covers and expose the metal hinge.
    • Unwrap the flex cable from around the hinge.
  19. Sony Handycam DCR-SR42 Flex Cable Replacement: 手順 19、 2の画像 1 Sony Handycam DCR-SR42 Flex Cable Replacement: 手順 19、 2の画像 2
    • Use the plastic opening tool to open the screen case.
  20. Sony Handycam DCR-SR42 Flex Cable Replacement: 手順 20、 2の画像 1 Sony Handycam DCR-SR42 Flex Cable Replacement: 手順 20、 2の画像 2
    • Unplug the flex cable from the sound chip.
    • Unplug the flex cable from the screen chip.
    Where can we I buy the Flex Cable
    Waymon - 返信
    aliexpress.com
    see full answer in comments, below.
    marko m - 返信
    FLEX-CABLE MOUNTING INSIDE THE SMALL BOX IS MISSING
    i had so much trouble and THIS MANUAL FAILED ME in this part. but i searched and found and only thanks to youtube video i completed the project.
    video called “Sony Handycam DCR-SR200E LCD Flip Screen Cable Replacement”
    https://www.youtube.com/watch?v=3slJNT68...
    marko m - 返信
終わりに
7 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Dan Muller
メンバー登録日: 03/23/15
1,020 ポイント
5のガイドは作成済み
チーム
Baylor, Team 7-13, Williams Spring 2015 Baylor, Team 7-13, Williams Spring 2015人のメンバー
BU-WILLIAMS-S15S7G13
4 メンバー
10のガイドは作成済み
15 件のコメント
Dear sir,
in step 20, there is a small switch at in flex cable...
where do need to place?
during open I did not notice.
Please help.
sunthar marugapah - 返信
Hey,
I'm not too sure. Try just pushing it back in.
Peter Kurapati -
At step 20, both cable contacts in the sound and screen chip are not fixed. They need to be carefully pulled out of the connector.
efr2et -
switch cable solution:
1. cable with switch goes to TOUCH the round rod so that the metal part will go near to rod.
there is a special slot made to that rod (so that it is not round from one place! take a look and find it) and thin metal sheet will hold it in place from outside and so do plastic covers. switch itself will touch the MIDDLE short rod that goes to lcd screen.
2. see pictures from 6 minutes and forward from youtube video called “Sony Handycam DCR-SR200E LCD Flip Screen Cable Replacement” ( https://www.youtube.com/watch?v=3slJNT68...). this helped me.
marko m -
right link is: https://www.youtube.com/watch?v=3slJNT68...
that is, within this … is/should be … xZE or last five digits are 68xZE
marko m -
Please: where i can buy the flexible cables to Sony?
Antonio - 返信
same question, where can you get the new part, does bestbuy has it?
Haichuan Yang -
not sure, but planning to buy from here:
https://www.aliexpress.com/wholesale?cat...
ebay had same cables with higher price, the ones i checked.
marko m -
i have positive experience with aliexpress.com
ordered: 13. nov
paid: ca 1 euro
package arrived: 28. nov
link:
https://www.aliexpress.com/item/LCD-Flex...
marko m -
Dear sir,
I can´t remember here I put the switch at in flex cable
pedro rocha - 返信
I'm having the same problem with the little switch. anyone figure out where it goes?
Colt Buzzell -
find posted solution to switch cable question above
marko m -
these directions are good but not detailed enough. Once you have the cable you have to fold it and twist into place, also a small metal piece fell out in section 15, I can not see where it belongs. Please send a pictorial or video of the folding of the new cable.Also a small piece of metal on the old cable looks like it came off of the PC board……Oh MY!
D Triche - 返信
Where can I buy the flex cable
Waymon - 返信
see my answer above.
(with link)
marko m -
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 32
過去 30 日: 60
今までの合計 4,475
