メインコンテンツにスキップ
Sony Handycam DCR-SR 47 Hard Drive Replacement
必要な工具と部品
  1. Sony Handycam DCR-SR 47 Hard Drive Replacement, Hard Drive: 手順 1、 1の画像 1
    • Remove the battery.
    • Use Philips #000 screwdriver to remove the 3mm screw under the battery
    • *t is recommended that you wait One Hour after removing the battery before disassembling the rest of the camera
  2. Sony Handycam DCR-SR 47 Hard Drive Replacement: 手順 2、 1の画像 1
    • Using the Phillips #000 screwdriver, remove all 6 of the 3mm screws located on the side of the camera.
    • This step seems unnecessary to initially find the Hard Drive, but will allow access to the attached flex cable
  3. Sony Handycam DCR-SR 47 Hard Drive Replacement: 手順 3、 1の画像 1
    • Using the Phillips #000 tool, remove the three 3mm screws from under the LCD screen
  4. Sony Handycam DCR-SR 47 Hard Drive Replacement: 手順 4、 2の画像 1 Sony Handycam DCR-SR 47 Hard Drive Replacement: 手順 4、 2の画像 2
    • Using the Phillips #000 screwdriver, remove the one 3mm screw on the back of the camera
    • Pull away the back shell of the camera, exposing the hard drive.
  5. Sony Handycam DCR-SR 47 Hard Drive Replacement: 手順 5、 3の画像 1 Sony Handycam DCR-SR 47 Hard Drive Replacement: 手順 5、 3の画像 2 Sony Handycam DCR-SR 47 Hard Drive Replacement: 手順 5、 3の画像 3
    • Gently pull the flex cable away from the hard drive. It should pop-off with minimal effort.
    • The black guard has been removed in the first picture. The guard does not need to be removed in order to reach hard drive and cable, but it does show the path that the cable takes
    • Once removing the flex cable, remove the plastic guard from the side of the hard drive.
終わりに
3 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Ragan Whitlock
メンバー登録日: 08/26/15
556 ポイント
4のガイドは作成済み
チーム
Western Carolina University, Team 1-2, Virtue Fall 2015 Western Carolina University, Team 1-2, Virtue Fall 2015人のメンバー
WCU-VIRTUE-F15S1G2
4 メンバー
8のガイドは作成済み
2 件のコメント
Hope somebody will see this. The battery in my Sony DVR-SR47 corroded (and the contacts in the camera) and I can't get it to charge or turn on. It has so many special videos on it, I'm desperate to save them somehow. I also have a friend's SR68 (copying the videos to DVD for her) and I'm wondering if there's any way I could make a Frankenstein camcorder out of the 2 of them? Specifically, put the SR47 hard drive into the functioning SR68. I know I can replace one drive with a bigger one, but it sounds like you need to format it to install it. That kind of defeats the whole purpose of rescuing my videos. My other thought was to try to transplant her working battery section to mine? I'm at a loss, I'd really appreciate any help. And are you seriously at WCU? We live by Everhart Park, crazy! Thx- Elizabeth ekmshops@gmail.com
Elizabeth McKeown - 返信
How can recover data from hard disc?
shah_hemali - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 10
過去 30 日: 66
今までの合計 1,836
