メインコンテンツにスキップ
Sony Handycam DCR-DVD103 Outer Cover Replacement
必要な工具と部品
  1. Sony Handycam DCR-DVD103 Outer Cover Replacement, Battery: 手順 1、 1の画像 1
    • Images do not show the camera's battery.
    • On the back of the camera beneath the viewfinder, locate the battery pack.
    • Press the small button.
    • Slide the switch forward.
  2. Sony Handycam DCR-DVD103 Outer Cover Replacement: 手順 2、 1の画像 1
    • Remove the battery from the camera.
    • To reinsert the battery, slide the battery into the camera.
  3. Sony Handycam DCR-DVD103 Outer Cover Replacement, Outer Cover: 手順 3、 1の画像 1
    • Using a #00 Phillips screwdriver, remove the six 4.5 mm screws from the camera's bottom.
  4. Sony Handycam DCR-DVD103 Outer Cover Replacement: 手順 4、 2の画像 1 Sony Handycam DCR-DVD103 Outer Cover Replacement: 手順 4、 2の画像 2
    • Remove the three 4.5 mm screws beneath the battery.
    • Remove the 2.9 mm screw from the right corner.
    • Remove the two 4.5 mm screws from the battery's right wall.
    • Images do not show the battery.
  5. Sony Handycam DCR-DVD103 Outer Cover Replacement: 手順 5、 1の画像 1
    • Remove the 4.5 mm screw under the output flap on the front of the camera below the lens.
  6. Sony Handycam DCR-DVD103 Outer Cover Replacement: 手順 6、 2の画像 1 Sony Handycam DCR-DVD103 Outer Cover Replacement: 手順 6、 2の画像 2
    • Remove the two 4.5 mm screws at the top of the camera.
    • Remove the 4.5 mm screw from the disk side of the camera (next to the lens).
  7. Sony Handycam DCR-DVD103 Outer Cover Replacement: 手順 7、 2の画像 1 Sony Handycam DCR-DVD103 Outer Cover Replacement: 手順 7、 2の画像 2
    • Extend the gray viewfinder, then gently remove the black plastic casing.
    • Caution: Plastic pieces are fragile.
  8. Sony Handycam DCR-DVD103 Outer Cover Replacement: 手順 8、 1の画像 1
    • Remove the two 2.9 mm screws under the black plastic casing.
  9. Sony Handycam DCR-DVD103 Outer Cover Replacement: 手順 9、 1の画像 1
    • Gently pull apart the outer silver case and screen.
    • Remove the copper wire strip to detach the case from the camera.
終わりに
ある他の人がこのガイドを完成しました。
作成者
8人の作成者と共同で作成されました。
kaitlin
メンバー登録日: 01/11/11
342 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 7-44, Regan Winter 2011 Cal Poly, Team 7-44, Regan Winter 2011人のメンバー
CPSU-REGAN-W11S7G44
5 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 2,438
