はじめに
The CX260V has a very complicated process in having to take apart all of the external panels in order to access the internal speaker and other internal items.
必要な工具と部品
Use a Phillips #00 screwdriver to remove the one 3mm and two 5mm screws located in the battery assembly area.
Using the screwdriver remove the two black 5mm screws located on the side of the speaker.
もう少しです!
終わりに
2 の人々がこのガイドを完成させました。
