メインコンテンツにスキップ
Sony Handycam CX260V Camera Lens Replacement
必要な工具と部品
  1. Sony Handycam CX260V Camera Lens Replacement, Sony Handycam CX260V Housing Disassembly: 手順 1、 1の画像 1
    • Use a Phillips #00 screwdriver to remove the one 3mm and two 5mm screws located in the battery assembly area.
  2. Sony Handycam CX260V Camera Lens Replacement: 手順 2、 1の画像 1
    • Remove the two 5mm screws located on the top left and bottom of the camera.
    • Remove the 3mm screw located in the middle of the joint attaching the LCD screen to the device.
  3. Sony Handycam CX260V Camera Lens Replacement: 手順 3、 1の画像 1
    • Remove the two 5mm screws from the panel to the right of the LCD screen.
  4. Sony Handycam CX260V Camera Lens Replacement: 手順 4、 1の画像 1
    • Use the plastic opening tool to remove the cover for the recording buttons.
  5. Sony Handycam CX260V Camera Lens Replacement: 手順 5、 1の画像 1
    • Remove the five 5mm screws located on the bottom panel.
    • Remove the bottom panel covering the internal motherboard.
  6. Sony Handycam CX260V Camera Lens Replacement: 手順 6、 1の画像 1
    • Remove the 5mm screw located by the lens and two 5mm screws located under the handle.
    • Remove the leather strap from the device.
  7. Sony Handycam CX260V Camera Lens Replacement: 手順 7、 1の画像 1
    • Remove the 5mm screw to the left of the Record button.
    • Remove the entire right-side panel where the leather strap was located.
  8. Sony Handycam CX260V Camera Lens Replacement: 手順 8、 1の画像 1
    • Use a spudger to remove the LCD joint cover.
  9. Sony Handycam CX260V Camera Lens Replacement: 手順 9、 2の画像 1 Sony Handycam CX260V Camera Lens Replacement: 手順 9、 2の画像 2
    • Remove the three black 5mm screws and one silver 4mm screw located on the front right-side of the camera, near the orange motherboard.
    • The silver screw is located on the front right-side of the camera and is attached to the main panel.
  10. Sony Handycam CX260V Camera Lens Replacement: 手順 10、 1の画像 1
    • Remove the 5mm screw located on the top left near the camera lens.
  11. Sony Handycam CX260V Camera Lens Replacement: 手順 11、 1の画像 1
    • Using tweezers, carefully detach the two wires connected to the bottom motherboard portion of the camera.
    • One white wire, one black wire, and one flat yellow wire are connected to the lens panel.
    • Remove the lens panel.
  12. Sony Handycam CX260V Camera Lens Replacement: 手順 12、 1の画像 1
    • Remove the three 5mm screws.
    • One is located at the bottom of the lens area, and the other two are on the top left and right of the lens area.
    • Carefully remove the camera lens with your hands or a spudger.
    • There are three springs located underneath the lens. Make sure to not lose them.
  13. Sony Handycam CX260V Camera Lens Replacement: 手順 13、 1の画像 1
    • Remove one 5mm screw located on the back left section near the zoom and picture control capturing button.
    • There are two flat blue wires keeping the buttons connected to the main assembly. Carefully set them aside or unplug them.
    • This partially removes the zoom and picture capturing control.
  14. Sony Handycam CX260V Camera Lens Replacement: 手順 14、 1の画像 1
    • Remove one silver 5mm screw located near the tripod mount.
    • Remove the tripod mount screw that has the mount assembly underneath.
  15. Sony Handycam CX260V Camera Lens Replacement: 手順 15、 1の画像 1
    • Remove the silver 5mm screw located on the front right side of the camera by the orange motherboard.
    • Unplug the wire.
    • Remove the silver 5mm screw underneath the wire.
  16. Sony Handycam CX260V Camera Lens Replacement: 手順 16、 1の画像 1
    • Using tweezers, release the clip attaching the main internal system to the mainframe. This allows the rest of the camera to be freely taken apart.
    • The side panel will have cords running through the frame. If you unplug these, the frame will be removable.
  17. Sony Handycam CX260V Camera Lens Replacement, Camera Lens: 手順 17、 2の画像 1 Sony Handycam CX260V Camera Lens Replacement, Camera Lens: 手順 17、 2の画像 2
    • Using the PH #00 size screw driver, unscrew one 5 millimeter screw located on the top left near the lens of the camera.
  18. Sony Handycam CX260V Camera Lens Replacement: 手順 18、 1の画像 1
    • Using a pair of tweezers, carefully disassemble the two wires connected to the bottom motherboard portion of the camera.
    • There is one white & black wire and one flat yellow wire that are connected to the lens panel.
  19. Sony Handycam CX260V Camera Lens Replacement: 手順 19、 2の画像 1 Sony Handycam CX260V Camera Lens Replacement: 手順 19、 2の画像 2
    • Using the screwdriver, locate the three five millimeter screws.
    • One is located on the bottom of the lens area, and the other two are located on the top left and right of the lens area.
    • Carefully remove the camera lens with your hands or spudger tool.
    • There are three springs located underneath the lens. (Make sure not to lose them).
終わりに
2 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Dominic Franklin
メンバー登録日: 04/07/15
285 ポイント
2のガイドは作成済み
チーム
Eastern Washington University, Team 1-5, Plummer Spring 2015 Eastern Washington University, Team 1-5, Plummer Spring 2015人のメンバー
EWU-PLUMMER-S15S1G5
4 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 6
今までの合計 585
