メインコンテンツにスキップ
Sony H.ear On 2 Charging Port Replacement
必要な工具と部品
  1. Sony H.ear On 2 Charging Port Replacement, Ear Cup: 手順 1、 2の画像 1 Sony H.ear On 2 Charging Port Replacement, Ear Cup: 手順 1、 2の画像 2
    • Start by inserting the iFixit plastic opening tool in the crease between the hard plastic and the ear cup, and then gently apply pressure until it separates. You may need to repeat the process on back until it is completely separate.
    • This may take a considerable amount of pressure, but do not force it.
  2. Sony H.ear On 2 Charging Port Replacement: 手順 2、 2の画像 1 Sony H.ear On 2 Charging Port Replacement: 手順 2、 2の画像 2
    • Use the JIS #00 Screwdriver to remove the five 6.4 mm screws holding the back plastic cover in place.
    • Then, turn the ear cup over and carefully lift the plastic cap off to reveal the internal components of the left ear cup.
    • This same process can be repeated on the right ear cup as well. Be aware the right cup is connected to the rest of the headphones via ribbon cable.
  3. Sony H.ear On 2 Charging Port Replacement, Charging Port: 手順 3、 2の画像 1 Sony H.ear On 2 Charging Port Replacement, Charging Port: 手順 3、 2の画像 2
    • Unscrew the single 6.4mm screw holding the IO board / charging board in place using the same JIS #00 screwdriver.
    • Lift out the board carefully, allowing the port to slide out of its holding easily.
    • You will need to wiggle the board back and forth to remove it from its place.
    • Be careful not to tear the ribbon connector holding the board in place. We will be removing it in the next step.
  4. Sony H.ear On 2 Charging Port Replacement: 手順 4、 3の画像 1 Sony H.ear On 2 Charging Port Replacement: 手順 4、 3の画像 2 Sony H.ear On 2 Charging Port Replacement: 手順 4、 3の画像 3
    • Now that you have the IO board removed from its housing, carefully pull the blue ribbon connector from the plastic locking mechanism holding it to the board.
    • Be gentle so you don't tear that connector. It is delicate and you will need it to reconnect to your replacement board.
ゴール
7 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Alec Saffer
メンバー登録日: 04/15/19
522 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team S9-G11, Maness Spring 2019 Cal Poly, Team S9-G11, Maness Spring 2019人のメンバー
CPSU-MANESS-S19S9G11
5 メンバー
16のガイドは作成済み
5 件のコメント
How much internal space is there inside the left ear cup? I’m considering attempting to mod my pair with a qi receiver possibly at the expense of the NFC chip.
Finn Atkinson - 返信
I cannot locate the IO board online. Is there somewhere you buy this board?
Jonathon Ingraham - 返信
I have the same question Jonathon, IO board is nowhere to be found online :/
sage.peter - 返信
The IO board looks to be part A-2182-326-A = "Sony L Jack Mounted Pc Board (Uc)". Is that correct?
flash - 返信
where can i find a replacement port?
Pass217 - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 11
過去 30 日: 53
今までの合計 3,596
