メインコンテンツにスキップ
Sony Ericsson z300 Front Speaker Replacement
必要な工具と部品
  1. Sony Ericsson z300 Front Speaker Replacement, Back Phone Cover: 手順 1、 1の画像 1
    • To remove the back cover, use your thumb to press down on the center of case and slide it off.
  2. Sony Ericsson z300 Front Speaker Replacement, Battery: 手順 2、 1の画像 1
    • Using a fingernail lift the battery out of the phone.
  3. Sony Ericsson z300 Front Speaker Replacement, Front Phone Cover: 手順 3、 1の画像 1
    • To remove the front cover, lift up the case with a fingernail in the small slot as shown.
  4. Sony Ericsson z300 Front Speaker Replacement, Front Dark Grey Case: 手順 4、 1の画像 1
    • To remove the front grey case, remove the two screws shown with a T5 Torx Screwdriver.
  5. Sony Ericsson z300 Front Speaker Replacement: 手順 5、 1の画像 1
    • Pry up the dark grey case with your fingernail until all four snaps around the top are loose.
  6. Sony Ericsson z300 Front Speaker Replacement: 手順 6、 1の画像 1
    • Lift up towards the bottom and slide the case off.
  7. Sony Ericsson z300 Front Speaker Replacement, Screens: 手順 7、 1の画像 1
    • Use a plastic opening tool to lift the black tape off of the ribbon cable connector.
  8. Sony Ericsson z300 Front Speaker Replacement: 手順 8、 1の画像 1
    • Lift the ribbon cable connector lock using a plastic opening tool.
  9. Sony Ericsson z300 Front Speaker Replacement: 手順 9、 2の画像 1 Sony Ericsson z300 Front Speaker Replacement: 手順 9、 2の画像 2
    • Slide the black ribbon cable tray out with a plastic opening tool.
    • Shown in the second picture is the try already slid out.
  10. Sony Ericsson z300 Front Speaker Replacement: 手順 10、 2の画像 1 Sony Ericsson z300 Front Speaker Replacement: 手順 10、 2の画像 2
    • Slide the ribbon cable out of the connector.
    • Shown in the second picture is the cable already out.
  11. Sony Ericsson z300 Front Speaker Replacement: 手順 11、 1の画像 1
    • Use a plastic opening tool to lift up on the screen board and release the clips holding it in place.
    • Lift the entire board out of the phone to remove both screens.
  12. Sony Ericsson z300 Front Speaker Replacement, Front Speaker: 手順 12、 1の画像 1
    • Use a plastic opening tool to lift the speaker out of its circular slot.
終わりに
作成者
4人の作成者と共同で作成されました。
Alex Serventi
メンバー登録日: 10/07/10
65 ポイント
13のガイドは作成済み
チーム
Cal Poly, Team 5-15, Maness Fall 2010 Cal Poly, Team 5-15, Maness Fall 2010人のメンバー
CPSU-MANESS-F10S5G15
4 メンバー
26のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 1,561
