必要な工具と部品
Grip the lower portion of the back of the phone and slide downwards.
Unscrew the four Torx screws from the backplate.
The backplate may begin to separate from the keypad face. Do not try to remove it yet.
The screws are T5 Torx screws, 5.6mm.
Remove the four black Phillips screws holding the swivel assembly to the LCD section of the phone.
The screws are Phillips, 2.4mm
The LCD display is connected to the device with a small flex cable. To release the cable, flip the small handle on the connector to an upright position.
ある他の人がこのガイドを完成しました。
