メインコンテンツにスキップ
Sony Ericsson s710a Keypad Replacement
必要な工具と部品
  1. Sony Ericsson s710a Keypad Replacement, Battery: 手順 1、 1の画像 1
    • Remove the back cover by sliding it off.
  2. Sony Ericsson s710a Keypad Replacement: 手順 2、 1の画像 1
    • Pull the battery out using your finger.
  3. Sony Ericsson s710a Keypad Replacement: 手順 3、 1の画像 1
    • The battery can now be replaced.
    • The battery is a 780 mAh rechargeable Lithium Ion battery.
  4. Sony Ericsson s710a Keypad Replacement, Keypad: 手順 4、 1の画像 1
    • Remove the four screws using a Phillips #00 screwdriver.
  5. Sony Ericsson s710a Keypad Replacement: 手順 5、 1の画像 1
    • Remove the plastic cover with the iFixit opening tool.
    • It is easiest to begin at the SD card slot and alternate prying the cover on opposite sides.
    • The cover will not come off completely, because there are additional screws that need to be removed, but will pry loose up to the camera.
  6. Sony Ericsson s710a Keypad Replacement: 手順 6、 1の画像 1
    • Using the iFixit opening tool, pry off the plastic piece at the bottom of the keypad.
    • This piece is fixed with an adhesive, so you must break the bond to reach the screws underneath. It may be necessary to use additional adhesive during reassembly.
  7. Sony Ericsson s710a Keypad Replacement: 手順 7、 1の画像 1
    • Remove two 6 mm screws from beneath the previously removed plastic cover using a Phillips #00 screwdriver.
    • Completely remove the back plastic cover.
  8. Sony Ericsson s710a Keypad Replacement: 手順 8、 2の画像 1 Sony Ericsson s710a Keypad Replacement: 手順 8、 2の画像 2
    • Pry the board from the plastic case using the iFixit opening tool.
    • This part is tricky. The black plastic pieces at the base of the phone hold the board in.
  9. Sony Ericsson s710a Keypad Replacement: 手順 9、 1の画像 1
    • After removing the board, you will see the plastic keyboard beneath. This can be removed by hand and is very flexible.
    • You have successfully removed the keypad. You can clean, decorate, or replace the keyboard without worrying about damaging the phone.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Alexander
メンバー登録日: 10/29/11
75 ポイント
4のガイドは作成済み
チーム
University of Maryland, Team 1-1, Calloway Fall 2011 University of Maryland, Team 1-1, Calloway Fall 2011人のメンバー
UMD-CALLOWAY-F11S1G1
3 メンバー
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 8
今までの合計 1,360
