はじめに
This guide will guide you through replacing the screen in a Sony Ericsson Z500a.
必要な工具と部品
Remove the back cover by pulling it down, and then take out the battery.
Using a T6 Torx screwdriver, remove the 4 screws.
Keep the phone open with the back cover facing you.
Use the opening tool to remove the 2 ribbon wires (boxed in the photo) from the logic board.
Close the phone, flip it over, grab the remaining gray covering of the phone and pull it straight up to remove it.
Once the cover is removed, remove the black piece underneath.
To remove the plastic cover on the screen, run the opening tool along the sides between the cover and the body of the phone (like you did for the keyboard) and gently pry upward until it is loose.
Grab the cover at the bottom of the screen (near the hinge) and pull outward while leaving the top (near the speaker) connected.
