メインコンテンツにスキップ
はじめに
This guide shows how to remove the phone keypad.
パーツ
パーツは指定されていません。
  1. Remove the back cover and the battery. Remove the back cover and the battery. Remove the back cover and the battery.
    • Remove the back cover and the battery.
  2. Remove the 4 screws using a T6 precision screwdriver.
    • Remove the 4 screws using a T6 precision screwdriver.
    • Flip open the phone, and keep the back cover facing you.
  3. iPhoneのバッテリーキット
    Only $29.99
    Buy Now
    iPhoneのバッテリーキット
    Only $29.99
    Buy Now
  4. Take the plastic opening tool and run it between the phone case and phone body to loosen the key pad while the phone is open. There are 2 clamps that lock it to the phone case (1 on each side).
    • Take the plastic opening tool and run it between the phone case and phone body to loosen the key pad while the phone is open.
    • There are 2 clamps that lock it to the phone case (1 on each side).
  5. Flip the phone over and lift straight up on the key pad to remove it.
    • Flip the phone over and lift straight up on the key pad to remove it.
    • Be sure to hold the phone flat (parallel to the table), because there are loose parts that may fall out.
まとめ
Jory Benitez
メンバー登録日: 2010年04月16日
1 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 7-12, Maness Spring 2010 Cal Poly, Team 7-12, Maness Spring 2010人のメンバー
CPSU-MANESS-S10S7G12
4 メンバー
10のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 2,600
