はじめに
Sony Ericsson X10 - how to disassemble the phone and replace the Touchscreen Glass.
必要な工具と部品
ビデオの概要
Use a Plastic Pry or other plastic tool to unhook the back housing / bezel and remove it.
Tip - try prying it open from the top and over to the side. It can be very tight if you are doing this for the first time. The volume rocker and camera button are not part of the housing, so try going around it.
Use a heat gun or a hairdryer and warm the glass.
With a cutter carefully make a room between the glass and the frame to insert a Plastic Pick.
Slowly separate the Touchscreen from the frame.
ある他の人がこのガイドを完成しました。
