はじめに
This guide will show how to replace the broken display assembly of your Sony Ericsson Xperia X10 smartphone. This guide will not show how to replace the glass.
必要な工具と部品
Place the phone with the back facing up. Remove the back cover and the battery.
Using a flat head screwdriver, pry up the board. Should have to pry from the left and from the right. Nothing is holding in the power button on the top of the phone, go ahead and remove it.
The piece on the right side of the picture is the LCD screen. It appears that the speakers and other components are directly attached to the LCD and must be replace as one unit.
To reassemble your device, follow these instructions in reverse order. The pieces need to be placed exactly back into the phone as they came out or else they won't fit together correctly.
3 の人々がこのガイドを完成させました。
