メインコンテンツにスキップ
Sony Ericsson Xperia Play Battery Replacement
必要な工具と部品
  1. Sony Ericsson Xperia Play Battery Replacement, Battery: 手順 1、 1の画像 1
    • Turn the phone around so the screen is facing a flat surface.
  2. Sony Ericsson Xperia Play Battery Replacement: 手順 2、 1の画像 1
    • To remove the cover, use plastic removal tool on the seam of the case.
    • Once enough force is applied, you should hear a “click” sound which indicates that cover is loose.
  3. Sony Ericsson Xperia Play Battery Replacement: 手順 3、 1の画像 1
    • After the “click” noise, lift the cover with your finger.
    • Do not puncture the battery. This can result in a fire.
  4. Sony Ericsson Xperia Play Battery Replacement: 手順 4、 1の画像 1
    • Proceed with removing the battery by lifting the battery with a small plastic pry tool.
    • Use a plastic tool for safety. If a plastic tool is not available use your fingers.
  5. Sony Ericsson Xperia Play Battery Replacement: 手順 5、 1の画像 1
    • Remove the battery from the device.
  6. Sony Ericsson Xperia Play Battery Replacement: 手順 6、 1の画像 1
    • Once the old battery id removed, slide the new battery, with the positive/negative indicator facing up, in so that the contacts of the battery make contact with the contacts of the phone.
  7. Sony Ericsson Xperia Play Battery Replacement: 手順 7、 1の画像 1
    • Lightly press the battery into the phone so that it is secure.
  8. Sony Ericsson Xperia Play Battery Replacement: 手順 8、 1の画像 1
    • To put the cover back on, apply force until a "click" sound is heard.
終わりに
作成者
1人の作成者と共同作成されました。
Pieter Boersma
メンバー登録日: 03/25/15
371 ポイント
3のガイドは作成済み
チーム
UMass Dartmouth, Team 7-3, Cichon Spring 2015 UMass Dartmouth, Team 7-3, Cichon Spring 2015人のメンバー
UMASSD-CICHON-S15S7G3
3 メンバー
3のガイドは作成済み
コメント 1 件
Has ifixit thought about trying to make a replacement battery that would work with this? It would be good to be able to get the battery from here as well, even if it is potentially a niche market for these old phones.
waytodawn0 - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 24
今までの合計 1,551
