はじめに
Replacing the speaker is pretty simple, just be sure to keep track of all of the parts.
必要な工具と部品
Insert the plastic opening tool in between the front case and the back case.
Apply downward pressure to make the case lift upwards, thus popping the front case off.
Pull back on the indicated tab of the white plastic cover to unhook it from the top of the phone.
Using the plastic opening tool, undo the indicated clip on the bottom of the white plastic cover.
Remove the white plastic cover.
Remove the speaker by pulling it up and out of place with the tweezers.
