メインコンテンツにスキップ
Sony Ericsson W200i Speaker Replacement
必要な工具と部品
  1. Sony Ericsson W200i Speaker Replacement, Disassembling Sony Ericsson W200i Battery: 手順 1、 2の画像 1 Sony Ericsson W200i Speaker Replacement, Disassembling Sony Ericsson W200i Battery: 手順 1、 2の画像 2
    • Slide the battery cover up and off the phone.
  2. Sony Ericsson W200i Speaker Replacement: 手順 2、 2の画像 1 Sony Ericsson W200i Speaker Replacement: 手順 2、 2の画像 2
    • Pop the battery out of its slot by lifting it up.
  3. Sony Ericsson W200i Speaker Replacement, Front Case: 手順 3、 3の画像 1 Sony Ericsson W200i Speaker Replacement, Front Case: 手順 3、 3の画像 2 Sony Ericsson W200i Speaker Replacement, Front Case: 手順 3、 3の画像 3
    • Insert the plastic opening tool in between the front case and the back case.
    • Apply downward pressure to make the case lift upwards, thus popping the front case off.
    • Use caution when removing the front case. It may seem stuck but just ease it out.
  4. Sony Ericsson W200i Speaker Replacement, Core: 手順 4、 2の画像 1 Sony Ericsson W200i Speaker Replacement, Core: 手順 4、 2の画像 2
    • Remove the 4 screws in the corners of the front of the phone using a T6 screwdriver.
    • Note that the top 2 screws are silver and the bottom 2 screws are black.
  5. Sony Ericsson W200i Speaker Replacement: 手順 5、 3の画像 1 Sony Ericsson W200i Speaker Replacement: 手順 5、 3の画像 2 Sony Ericsson W200i Speaker Replacement: 手順 5、 3の画像 3
    • There is a black tab in the top left corner holding the core in place.
    • Remove the core by pulling straight up to prevent breaking the tab.
  6. Sony Ericsson W200i Speaker Replacement, Back Case: 手順 6、 3の画像 1 Sony Ericsson W200i Speaker Replacement, Back Case: 手順 6、 3の画像 2 Sony Ericsson W200i Speaker Replacement, Back Case: 手順 6、 3の画像 3
    • Pull back on the indicated tab of the white plastic cover to unhook it from the top of the phone.
    • Using the plastic opening tool, undo the indicated clip on the bottom of the white plastic cover.
    • Remove the white plastic cover.
  7. Sony Ericsson W200i Speaker Replacement, Speaker: 手順 7、 2の画像 1 Sony Ericsson W200i Speaker Replacement, Speaker: 手順 7、 2の画像 2
    この手順で使用する道具:
    購入する
    • Remove the speaker by pulling it up and out of place with the tweezers.
終わりに
作成者
4人の作成者と共同で作成されました。
Andy Whitmyre
メンバー登録日: 01/12/11
147 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 14-10, Forte Winter 2011 Cal Poly, Team 14-10, Forte Winter 2011人のメンバー
CPSU-FORTE-W11S14G10
5 メンバー
16のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 13
今までの合計 4,828
