はじめに
Removing the front case is easy, just be careful when you take it off.
必要な工具と部品
Insert the plastic opening tool in between the front case and the back case.
Apply downward pressure to make the case lift upwards, thus popping the front case off.
もう少しです!
To reassemble your device, follow these instructions in reverse.
終わりに
ある他の人がこのガイドを完成しました。
