はじめに
How to change / replace Touch Screen / Digitizer - Sony Ericsson Vivaz U5, also known as Sony Ericsson Kurara!
Video Guide
ビデオの概要
  1. First remove battery, sim card and memory card. You must remove seven screws. First remove battery, sim card and memory card. You must remove seven screws. First remove battery, sim card and memory card. You must remove seven screws.
    • First remove battery, sim card and memory card. You must remove seven screws.
  2. Now remove this part.
    • Now remove this part.
  3. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  4. This baseboards are sticked with a double-sided tape. This baseboards are sticked with a double-sided tape. This baseboards are sticked with a double-sided tape.
    • This baseboards are sticked with a double-sided tape.
  5. Remove the Touch Screen! To be more easy, heat it with hot air before doing so! Remove the Touch Screen! To be more easy, heat it with hot air before doing so! Remove the Touch Screen! To be more easy, heat it with hot air before doing so!
    • Remove the Touch Screen! To be more easy, heat it with hot air before doing so!
  6. Now is the time for the new Touch Screen. Now is the time for the new Touch Screen. Now is the time for the new Touch Screen.
    • Now is the time for the new Touch Screen.
  7. Test, assembling and... that is all. . Please SUBSCRIBE to my channel  ツ
まとめ
ある他の人がこのガイドを完成しました。
ZFix
メンバー登録日: 2013年12月09日
162,377 ポイント
304のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
280 メンバー
783のガイドは作成済み
統計データを表示:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 16
今までの合計 2,176
