メインコンテンツにスキップ
Sony Ericsson QuickShare T630 Screen Replacement
必要な工具と部品
  1. Sony Ericsson QuickShare T630 Screen Replacement, Sony Ericsson QuickShare T630 Phone Enclosure: 手順 1、 1の画像 1
    • Begin the disassembly by placing your Sony Ericsson QuickShare T630 on a flat surface.
  2. Sony Ericsson QuickShare T630 Screen Replacement: 手順 2、 2の画像 1 Sony Ericsson QuickShare T630 Screen Replacement: 手順 2、 2の画像 2
    • Slide the protective panel on the backside of the phone downward and remove it entirely, revealing the battery underneath.
  3. Sony Ericsson QuickShare T630 Screen Replacement: 手順 3、 1の画像 1
    • Slide the battery upward to remove.
  4. Sony Ericsson QuickShare T630 Screen Replacement: 手順 4、 2の画像 1 Sony Ericsson QuickShare T630 Screen Replacement: 手順 4、 2の画像 2
    • Remove the rubber plug located near the camera by gently prying upward with your fingers.
    • Gently lift the camera shield after removal of the rubber plug.
  5. Sony Ericsson QuickShare T630 Screen Replacement: 手順 5、 2の画像 1 Sony Ericsson QuickShare T630 Screen Replacement: 手順 5、 2の画像 2
    • Pry the remaining panel to loosen its contact to the phone using a spudger.
    • Slide the panel upward to remove it completely.
    • These steps will require a slight appliance of force.
  6. Sony Ericsson QuickShare T630 Screen Replacement: 手順 6、 1の画像 1
    • Slide the aerial upward to remove it.
  7. Sony Ericsson QuickShare T630 Screen Replacement: 手順 7、 2の画像 1 Sony Ericsson QuickShare T630 Screen Replacement: 手順 7、 2の画像 2
    • Remove the four screws located at each corner of the device.
  8. Sony Ericsson QuickShare T630 Screen Replacement: 手順 8、 2の画像 1 Sony Ericsson QuickShare T630 Screen Replacement: 手順 8、 2の画像 2
    • Gently lift and remove the front panel of the phone after removing the screws.
  9. Sony Ericsson QuickShare T630 Screen Replacement: 手順 9、 3の画像 1 Sony Ericsson QuickShare T630 Screen Replacement: 手順 9、 3の画像 2 Sony Ericsson QuickShare T630 Screen Replacement: 手順 9、 3の画像 3
    • This step is NOT required for joystick maintenance or keypad maintenance and replacement! Continue on to step 10 if you are attempting to achieve either of these goals.
    • Slowly lift the screen to reveal the green circuit ribbon connecting the screen to the phone.
    • Gently pull the ribbon from the circuit.
    • Remove the now disconnected screen.
  10. Sony Ericsson QuickShare T630 Screen Replacement: 手順 10、 3の画像 1 Sony Ericsson QuickShare T630 Screen Replacement: 手順 10、 3の画像 2 Sony Ericsson QuickShare T630 Screen Replacement: 手順 10、 3の画像 3
    • Remove the keyboard by slowly pulling it away from the circuit board.
    • There are no direct connections between the keyboard and phone.
    • These are all of the parts covered in this disassembly that make up the Sony Ericsson QuickShare T630.
  11. Sony Ericsson QuickShare T630 Screen Replacement, Sony Ericsson QuickShare T630 Screen: 手順 11、 3の画像 1 Sony Ericsson QuickShare T630 Screen Replacement, Sony Ericsson QuickShare T630 Screen: 手順 11、 3の画像 2 Sony Ericsson QuickShare T630 Screen Replacement, Sony Ericsson QuickShare T630 Screen: 手順 11、 3の画像 3
    • To place a new screen, slide the green ribbon connector into the ribbon clamp that the defective screen was pulled from.
終わりに
ある他の人がこのガイドを完成しました。
作成者
6人の作成者と共同で作成されました。
Jeremy
メンバー登録日: 10/16/13
166 ポイント
1ガイドが承認済み
チーム
University of Maine, Team 1-1, Diaz Fall 2013 University of Maine, Team 1-1, Diaz Fall 2013人のメンバー
UMAINE-DIAZ-F13S1G1
4 メンバー
6のガイドは作成済み
コメント 1 件
Worked well until the screen replacemet - ribbon cable would not go into clamp - phone plus new screen straight in the bin - a little gutted - but hey it was an old but loved phone.
roger hiley - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 1,352
