はじめに
In these instructions you will learn how to replace the joystick in a Sony Ericsson K750i
必要な工具と部品
Remove the battery cover.
Press down firmly with your thumb and slide the cover back.
Remove two Phillips #0 screws from the battery chamber.
Remove two Torx T6 screws from the battery chamber.
3 の人々がこのガイドを完成させました。
コメント 1 件
That is the joystick head and it can be removed without taking anything apart. The problem is in joystick underneath it, which is soldered and need to be replaced. I know this phone is 15 years old, I just found mine and it brought back some memories :)
