メインコンテンツにスキップ
Sony Ericsson J22Oi Charging Port Replacement
必要な工具と部品
  1. Sony Ericsson J22Oi Charging Port Replacement, Battery: 手順 1、 1の画像 1
    • Before disassembling the phone, make sure the phone is powered off.
  2. Sony Ericsson J22Oi Charging Port Replacement: 手順 2、 1の画像 1
    • Flip to the back of the phone and locate the black button on the top of the phone.
  3. Sony Ericsson J22Oi Charging Port Replacement: 手順 3、 1の画像 1
    • Firmly hold down the black button on the top of the phone and gently snap off the back cover.
  4. Sony Ericsson J22Oi Charging Port Replacement: 手順 4、 1の画像 1
    • Remove the battery by wedging it out from the back.
  5. Sony Ericsson J22Oi Charging Port Replacement, Keypad: 手順 5、 1の画像 1
    • Flip to the front of the phone and apply pressure to the front frame of the phone. The frame should snap off easily.
  6. Sony Ericsson J22Oi Charging Port Replacement: 手順 6、 1の画像 1
    • Remove the keypad by gently pulling it from the front of the phone.
  7. Sony Ericsson J22Oi Charging Port Replacement, Screen: 手順 7、 1の画像 1
    • Locate the five screws indicated on the phone.
  8. Sony Ericsson J22Oi Charging Port Replacement: 手順 8、 1の画像 1
    • Use a T5 Screwdriver and unscrew the five screws.
  9. Sony Ericsson J22Oi Charging Port Replacement: 手順 9、 1の画像 1
    • Once the screws are off, there should be a plastic cover on top of your screen. Gently slide the plastic cover off.
  10. Sony Ericsson J22Oi Charging Port Replacement: 手順 10、 1の画像 1
    • Now gently pull metal cover off.
  11. Sony Ericsson J22Oi Charging Port Replacement: 手順 11、 1の画像 1
    • You should now see the screen on the front side of the phone. Wedge your finger to the side of the phone. Apply some force to pop out the screen.
  12. Sony Ericsson J22Oi Charging Port Replacement: 手順 12、 1の画像 1
    • Now that screen is removed, replace the old screen with the new screen.
    • Reassemble the device by doing the steps in reverse order.
  13. Sony Ericsson J22Oi Charging Port Replacement, Charging Port: 手順 13、 1の画像 1
    • After removing the screen, you will find the charging port located at the bottom of the phone.
  14. Sony Ericsson J22Oi Charging Port Replacement: 手順 14、 1の画像 1
    • Gently slide off the charging port.
終わりに
作成者
6人の作成者と共同で作成されました。
James Au
メンバー登録日: 10/06/12
10 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 6-36, Regan Fall 2012 Cal Poly, Team 6-36, Regan Fall 2012人のメンバー
CPSU-REGAN-F12S6G36
3 メンバー
10のガイドは作成済み
コメント 1 件
Nice information for me , I also repairing the mobile phone
Mohit - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 6
今までの合計 1,381
