はじめに
This guide will show the user how to disassemble a Sony Ericsson J22Oi with the intent of removing and replacing the charging port.
パーツ
パーツは必要ありません。
  1. Before disassembling the phone, make sure the phone is powered off.
    • Before disassembling the phone, make sure the phone is powered off.
  2. Flip to the back of the phone and locate the black button on the top of the phone.
    • Flip to the back of the phone and locate the black button on the top of the phone.
    • Firmly hold down the black button on the top of the phone and gently snap off the back cover.
    • Remove the battery by wedging it out from the back.
    • Flip to the front of the phone and apply pressure to the front frame of the phone. The frame should snap off easily.
    • Remove the keypad by gently pulling it from the front of the phone.
    • Locate the five screws indicated on the phone.
    • Use a T5 Screwdriver and unscrew the five screws.
    • Once the screws are off, there should be a plastic cover on top of your screen. Gently slide the plastic cover off.
    • Now gently pull metal cover off.
    • You should now see the screen on the front side of the phone. Wedge your finger to the side of the phone. Apply some force to pop out the screen.
    • Now that screen is removed, replace the old screen with the new screen.
    • Reassemble the device by doing the steps in reverse order.
    • After removing the screen, you will find the charging port located at the bottom of the phone.
    • Gently slide off the charging port.
まとめ
James Au
メンバー登録日: 2012年10月06日
10 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 6-36, Regan Fall 2012 Cal Poly, Team 6-36, Regan Fall 2012人のメンバー
CPSU-REGAN-F12S6G36
3 メンバー
10のガイドは作成済み
コメント1件
Nice information for me , I also repairing the mobile phone
Mohit - 返信
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 1,115
