メインコンテンツにスキップ
Sony ECM-MS907 Volume issue troubleshooting
  1. Sony ECM-MS907 Volume issue troubleshooting, Sony ECM-MS907 Volume issue troubleshooting: 手順 1、 2の画像 1 Sony ECM-MS907 Volume issue troubleshooting, Sony ECM-MS907 Volume issue troubleshooting: 手順 1、 2の画像 2
    • Often when using the recording range of 90 degrees, a low recording occurs. This particular setting seems tailored towards a much louder object, such as a musical instrument, etc.
    • To change this setting, change switch to the 120 degree recording range.
  2. Sony ECM-MS907 Volume issue troubleshooting: 手順 2、 1の画像 1
    • Another problem involves the stereo jack of the microphone being inserted into the wrong output of the external device.
  3. Sony ECM-MS907 Volume issue troubleshooting: 手順 3、 2の画像 1 Sony ECM-MS907 Volume issue troubleshooting: 手順 3、 2の画像 2
    • In this particular external device, the Sony MiniDisc player, the microphone stereo jack can mistakenly be inserted into the laptop, or "white" input.
    • Always remember to insert stereo jack into the microplug, or "red" input.
  4. Sony ECM-MS907 Volume issue troubleshooting: 手順 4、 1の画像 1
    • Some volume issues could be related to other external devices, such as a laptop. This particular microphone was not designed to be used with a computer.
  5. Sony ECM-MS907 Volume issue troubleshooting: 手順 5、 1の画像 1
    • One solution is to use a device such as a USB soundcard, which can be purchased online or at most electronics stores.
    • Simply insert soundcard into a USB input in the laptop
    • Insert stereo jack of microphone into the soundcard input marked with the "microphone" symbol.
    • This may resolve laptop related problems related to low volume during recordings.
終わりに
作成者
7人の作成者と共同で作成されました。
Justin Lewis
メンバー登録日: 01/23/14
242 ポイント
2のガイドは作成済み
チーム
New Mexico State, Team 1-2, Sheppard Spring 2014 New Mexico State, Team 1-2, Sheppard Spring 2014人のメンバー
NMSU-SHEPPARD-S14S1G2
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 10
今までの合計 1,196
