はじめに
Buy a new AA battery of any brand you like.
ツール
パーツ
パーツは必要ありません。
  1. Take off the windshield from the top of the microphone and place aside. The bottom part of the microphone is detachable. In a clockwise motion, begin unscrewing the bottom of the microphone from its base.
    • Take off the windshield from the top of the microphone and place aside. The bottom part of the microphone is detachable. In a clockwise motion, begin unscrewing the bottom of the microphone from its base.
  2. Pull off the bottom base of the microphone. The microphone should now be in two pieces. After the bottom base is removed, the battery should now be visible. Pull off the bottom base of the microphone. The microphone should now be in two pieces. After the bottom base is removed, the battery should now be visible.
    • Pull off the bottom base of the microphone. The microphone should now be in two pieces. After the bottom base is removed, the battery should now be visible.
  3. To remove the battery, push it upward into the aluminum spring. This will loosen and free the battery.
    • To remove the battery, push it upward into the aluminum spring. This will loosen and free the battery.
  4. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  5. Select a new, (AA) battery to insert into the microphone. Match the (+) and (-) sides of the battery to the matching symbols inside the microphone. Select a new, (AA) battery to insert into the microphone. Match the (+) and (-) sides of the battery to the matching symbols inside the microphone.
    • Select a new, (AA) battery to insert into the microphone. Match the (+) and (-) sides of the battery to the matching symbols inside the microphone.
  6. Reconnect the bottom and top base of the microphone by pushing them together.
    • Reconnect the bottom and top base of the microphone by pushing them together.
  7. Attach the bottom base by turning it counter-clockwise.
    • Attach the bottom base by turning it counter-clockwise.
  8. Place the windshield back onto the top of the microphone.
    • Place the windshield back onto the top of the microphone.
  9. Insert stereo jack of microphone into external device. Test the microphone. This should fix the problem, otherwise issues may exist elsewhere. Insert stereo jack of microphone into external device. Test the microphone. This should fix the problem, otherwise issues may exist elsewhere.
    • Insert stereo jack of microphone into external device. Test the microphone. This should fix the problem, otherwise issues may exist elsewhere.
まとめ
2 の人々がこのガイドを完成させました。
Kefaya
メンバー登録日: 2014年01月23日
343 ポイント
3のガイドは作成済み
チーム
New Mexico State, Team 1-2, Sheppard Spring 2014 New Mexico State, Team 1-2, Sheppard Spring 2014人のメンバー
NMSU-SHEPPARD-S14S1G2
3 メンバー
5のガイドは作成済み
統計データを表示:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 35
今までの合計 2,688
