はじめに
この修理ガイドをつかって、Sony DualSense コントローラー L1/ R1ボタンを交換してします。
修理を始める前に、コントローラの接続を外して電源を切ってください。
必要な工具と部品
R1ボタン上の隙間にスパッジャーの平面側先端を差し込みます。
R1ボタンを上にむけてこじあけて、取り出します。
What I didn't see addressed anywhere (here or in other similar articles) is that replacement R1 / L1 buttons can be differ enough to be un-usable depending on which model your ps5 controller is. The ones I ordered don't fit and now I can't find a way to be sure I get the right ones because few know there's even a difference.
Did you already figured it out? The version the we need yo use?, We are in the same situation here.
Tried prying from the front of the buttons as pictured and my spudger broke off in the gap. A video I watched showed them being pried off from the back (between the R1/R2 and L1/L2 buttons) which seemed much easier.
このデバイスを再組み立てするには、インストラクションを逆の順番に従って作業を進めてください。
e-wasteを処理する場合は、認可済みリサイクルセンターR2を通じて廃棄してください。
修理が上手く進みませんか?ベーシックなトラブルシューティングを試してみるか、DualSenseのアンサーコミュニティを参照してください。
3 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
翻訳を始める ›
3 件のコメント
It is easier to remove L1/R1 by going from below than by from above- without any damages.
Does the spudger dent or mark the button when doing this?
My replacement R1 button is different enough to not fit. Fins around center sleeve are wider. So there must have been a design change at some point.
Lora Singleton - 返信
Agree with Lora's comment above. I was able to use an old credit card to take L1/R1 out this way. I pressed down the L2/R2 button to create space to work in, then came in from between L1/L2 and R1/R2. It's easy to pop one of the outer corners first then you can work the credit card around the top and the rest falls out.
darkstar448 - 返信
Man, if I'd just read the thumb part...
caldugen - 返信
