はじめに
Sony PlayStation 5 DualSenseコントローラーのフロントケースを交換する方法です。
注意: このガイドは、FCC IDが1で終わるDualSenseコントローラ用です。コントローラの裏面をご覧になり、モデルをご確認ください。A で終わる場合は、内部設計に違いがあります。
必要な工具と部品
L1ボタン上の隙間にスパッジャーの先端を差し込みます。
L1ボタンを上にむけてこじ開けて、取り出します。
Tried prying from the front of the buttons as pictured and my spudger broke off in the gap. A video I watched showed them being pried off from the back (between the R1/R2 and L1/L2 buttons) which seemed much easier.
Agree with Lora's comment above. I was able to use an old credit card to take L1/R1 out this way. I pressed down the L2/R2 button to create space to work in, then came in from between L1/L2 and R1/R2. It's easy to pop one of the outer corners first then you can work the credit card around the top and the rest falls out.
R1ボタン上の隙間にスパッジャーの平面側先端を差し込みます。
R1ボタンを上にむけてこじあけて、取り出します。
What I didn't see addressed anywhere (here or in other similar articles) is that replacement R1 / L1 buttons can be differ enough to be un-usable depending on which model your ps5 controller is. The ones I ordered don't fit and now I can't find a way to be sure I get the right ones because few know there's even a difference.
Did you already figured it out? The version the we need yo use?, We are in the same situation here.
スパッジャーの先端を使って、ハードセットジャックの両側に留められた2つのクリップを外します。
If these are similar in nature to the DS4’s clips, don’t use too much force so you don’t end up breaking them
there is a clip that holds the rear cover in place located in R1 and L1
For those wondering where the bumper clip is located, it's ~1cm inwards from the end of the back shell where the bumpers are. Take a spudger in that spot and lift it upwards carefully, it should disconnect the clips if they aren't already
リアケースを外します。
あるリビジョン版モデルによっては、リアケースは以前に取り外したバンパーの横に追加の2つのクリップで固定されています。リアケースが自然に開かない場合は、これらのクリップがあるかどうか確認してください。
There are four more clips/hooks hidden in the seams along the outer sides of the handles. If you pull open the controller as shown in this step, then you will shear off the two tiny clips which are right next to the R1 and L1 buttons.
Therefore, you should first release those clips by prying the seams open sideways.
I noticed this with the updated design of the controller, not sure whether the hooks are present on the first version.
The hooks are not critical for the integrity of the controller as the two halves are held together by the screws hidden under the buttons. The damage does show that the controller has been taken apart.
Thought I'd clarify: The clips next to the L1 and R1 are on the outer side from the L1 and R1 buttons, I'd suggest zooming in on the picture to see them. They're quite easy to break, but also easy to remove using the plastic spudger along the seam, bending the bottom cover outwards
I am still strugling to find the clips. Could someone point them out in the image with a screen shot or something like that.
I keep getting stuck at this step too with the new DualSense CFI-ZCT1WA revision. The top and bottom shells seem like they are fused together next to L1/R1 but I can't seem to be able to find where these hidden clips are located. My controller is still in warranty so I don't want to break them in case I can't fix my issue.
I tried this but it seems that the you need a lot of force and I ended up bending the tip of my spudger. Are you sure it's not the top cover that you need to pry away? The bottom cover has a ridge to make sure it's under the top cover so it's not easy to bend outwards.
@samomio I think there needs to be a step added for these new clips.
Ok, not seeing a lot of motion on this request, so I've uploaded photos of the hooks to imgur.
Here ya go: https://imgur.io/a/7NWmQi5
This guide really needs an update on this. I had a really hard time getting the forward clips to release even after referring to the comments above. Pretty sure I broke them in the end. No big deal but would be great if the iFixit experts could work out a good method for releasing them.
I finally figure it out!!
The hidden clip is very tricky but once you understand how it works it is easy to remove.
Use Sean's picture: https://imgur.io/a/7NWmQi5
What sean is showing, is actually the bottom shell of the seam.
To disassemble
1. Use the flat side of the spudger, pry the bottom seam OUTWARDS near the R1/L1 button hole.
2. (most important) While prying the bottom shell seam outwards, push your thumb on the upper shell and push outward as well (you can do this by applying pressure from the removed R1/L1 button hole towards the seam. And then it will disassemble automatically
And that's it!
updated instruction:
To disassemble
2. (most important) While prying the bottom shell seam outwards, hold your thumb on the upper shell as anchor and then use your other finger to pry the bottom edge of the controller up away from the shell. If you are doing the first step, then don't worry about breaking the clip, just force it open. And then it will disassemble automatically
And that's it!
I managed to do it just by pulling harder than what I was already doing. And I don't think I broke anything. So, for me at least, the technique described in this guide worked.
ピンセットもしくは指で、マザーボードからバッテリーの接続を外します。
Tweezers aren't gonna grip that the way you need.
For those having trouble using tweezers to pull out the connector, you can grab below the lip of the connector and use the controller as a lever to pull it up as seen here DualSense コントローラー v2 バッテリーの交換
This little trick helped me so much and I believe it should be shown on this guide as well.
下部マイクのリボンケーブルのプルタブを指またはピンセットでつかみ、マザーボードから取り外します。
These ribbon cables have small tabs on either side you can use to help pull out the cable. You can slightly pull up, alternating between the two sides, to slowly wiggle the connector out.
マザーボードからバッテリーのブラケットを持ち上げて取り出します。
Black and red wires fit neatly under the lower left and lower right arms of the battery bracket, to avoid potential damage when reconnecting the rear case.
This needs to be noted. Thanks!
ピンセットや指を使って上部マイクリボンケーブルのプルタブをつかみ、引き上げてマザーボードから外します。
フロントケースからJoystickを慎重に通してひき抜き、マザーボードを持ち上げて取り出します。
My motherboard wouldn't just lift right out. So I noticed there's also a pair of barely visible small black clips, one on each side of the motherboard, holding it down. One is right beside the battery connector and the other's directly across on the opposite side of the motherboard right beside the ribbon cable connector.
Such a good observation!
zidek22 -
Just push on the sticks. Pops out like a charm, zero effort.
プラスドライバーを使って、ライトガイドを固定している8.5mmのネジを2本外します。
ピンセットを使って、ミッドフレームからスピーカーを取り出します。
ミッドフレームとマザーボードを慎重に持ち上げて、フロントケースから取り出します。
再組み立ての際、 タッチパッドのリボンケーブルを、ミッドフレームの長方形の開口部に通して戻します。
Feed the ribbon cable back through the rectangular slot in the midframe during reassembly.
Thank you for catching this!
プラスドライバーを使って、タッチパッドにタッチパッドブラケットを固定している6.4mmネジを2本外します。
On my early 2022 controller it only had one screw, the other side was a hook, i was able to separate them but pulling the touch pad up slightly away from the top of the controller and pushing towards the side the one screw was on.
Ryan Hynes - 返信
Question where can a buy a brand New touch pad replacement. I ripped mijn ribbon cable from the touch pad and cant seem to fix it please help
タッチパネルからフロントケースを持ち上げて外します。
not sure, but i’m currently trying to take the logic board off of my track pad, idk how to
このデバイスを再組み立てするには、インストラクションを逆の順番に従って作業を進めてください。
e-wasteを処理する場合は、認可済みリサイクルセンターR2を通じて廃棄してください。
修理が上手く進みませんか?ベーシックなトラブルシューティングを試してみるか、DualSenseのアンサーコミュニティを参照してください。
13 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
翻訳を始める ›
2 件のコメント
need an update for the “a” variant (cfi-zct1w a)
this guide works for it up until a point (the touchpad), the a variant only has 1 screw instead of two and i couldn’t get the touchpad itself removed from it’s bracket (steps 30/31)
also the “a” variant is missing the light guide bracket (step 25)
