はじめに
If the device has a dim display, isn't staying on or simply fails to power on; it may be time to replace the battery. Please see the Sony Dream Machine ICF-C717PJ Troubleshooting page: Sony Dream Machine ICF-C717PJ to eliminate other possible issues before replacing the battery. This guide will help to assist you in replacing the battery on Sony Dream Machine ICF-C717PJ.
必要な工具と部品
To start, use a small phillips screwdriver, to remove the screw located on the battery component on the back of the device.
ある他の人がこのガイドを完成しました。
