メインコンテンツにスキップ
はじめに
Removing the processing board allows you to access other components like the DVD drive and remaining circuit boards.
パーツ
パーツは指定されていません。
  1. Sony DVP-SR200P Processing Board Replacement, Top Cover: 手順 1、 2の画像 1 Sony DVP-SR200P Processing Board Replacement, Top Cover: 手順 1、 2の画像 2
    • Remove the five #1 Phillips screws (black, 3/16") attaching the cover to the DVD player.
    • One 3/16" screw on the right side of the DVD player.
    • One 3/16" screw on the left side of the DVD player (directly opposite of other screw).
    • Three 3/16" screws on the back of the DVD player.
  2. Sony DVP-SR200P Processing Board Replacement: 手順 2、 2の画像 1 Sony DVP-SR200P Processing Board Replacement: 手順 2、 2の画像 2
    • Slide the cover away from the front of the DVD player until it is off.
  3. Sony DVP-SR200P Processing Board Replacement, Processing Board: 手順 3、 1の画像 1
    • Remove the blue tape from the processing board by gently pulling upward.
  4. Sony DVP-SR200P Processing Board Replacement: 手順 4、 2の画像 1 Sony DVP-SR200P Processing Board Replacement: 手順 4、 2の画像 2
    • Use the tweezers to remove the four sets of wires connected to the processing board. Start with the cord located in front of the row of three cords.
    • The wires may be difficult to remove. Wiggling them while lifting them up may help remove them.
  5. Sony DVP-SR200P Processing Board Replacement: 手順 5、 1の画像 1
    • Handle the processing board with care. It is fragile.
    • Unscrew the two #1 Phillips screws (silver, 3/16") located on the two edge corners of the processing board.
  6. Sony DVP-SR200P Processing Board Replacement: 手順 6、 1の画像 1
    • Orient the DVD player so that you are facing the video and audio jacks.
    • Unscrew the two #1 Phillips screws (silver, 3/16") located on the outside of the DVD player
    • The processing board is now free to be removed and replaced.
終わりに
Brian Hua
メンバー登録日: 2013年01月11日
74 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 5-17, Forte Winter 2013 Cal Poly, Team 5-17, Forte Winter 2013人のメンバー
CPSU-FORTE-W13S5G17
5 メンバー
6のガイドは作成済み
2 件のコメント
I have Sony DVD player dvp at510p. After switching it runs then automatic Power go down while running it's process ic get hotter and hotter what's the right solutions plz help me
Dhiraj Vasave - 返信
SO my DVD player run 5to 6 minutes then automatic stop all power goes to less
Dhiraj Vasave - 返信
コメントを追加
統計データを表示:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 9
今までの合計 1,592
