メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Sony DVP-SR200P DVD Reader Replacement
必要な工具と部品
    1. Sony DVP-SR200P DVD Reader Replacement, Top Cover: 手順 1、 2の画像 1 Sony DVP-SR200P DVD Reader Replacement, Top Cover: 手順 1、 2の画像 2
      • Remove the five #1 Phillips screws (black, 3/16") attaching the cover to the DVD player.
      • One 3/16" screw on the right side of the DVD player.
      • One 3/16" screw on the left side of the DVD player (directly opposite of other screw).
      • Three 3/16" screws on the back of the DVD player.
      FixBotに聞いてみる
      コメントを追加
    2. Sony DVP-SR200P DVD Reader Replacement: 手順 2、 2の画像 1 Sony DVP-SR200P DVD Reader Replacement: 手順 2、 2の画像 2
      • Slide the cover away from the front of the DVD player until it is off.
      FixBotに聞いてみる
      コメントを追加
    1. Sony DVP-SR200P DVD Reader Replacement, Processing Board: 手順 3、 1の画像 1
      • Remove the blue tape from the processing board by gently pulling upward.
      FixBotに聞いてみる
      コメントを追加
    2. Sony DVP-SR200P DVD Reader Replacement: 手順 4、 2の画像 1 Sony DVP-SR200P DVD Reader Replacement: 手順 4、 2の画像 2
      この手順で使用する道具:
      • Use the tweezers to remove the four sets of wires connected to the processing board. Start with the cord located in front of the row of three cords.
      • The wires may be difficult to remove. Wiggling them while lifting them up may help remove them.
      FixBotに聞いてみる
      コメントを追加
    3. Sony DVP-SR200P DVD Reader Replacement: 手順 5、 1の画像 1
      • Handle the processing board with care. It is fragile.
      • Unscrew the two #1 Phillips screws (silver, 3/16") located on the two edge corners of the processing board.
      FixBotに聞いてみる
      コメントを追加
    4. Sony DVP-SR200P DVD Reader Replacement: 手順 6、 1の画像 1
      • Orient the DVD player so that you are facing the video and audio jacks.
      • Unscrew the two #1 Phillips screws (silver, 3/16") located on the outside of the DVD player
      • The processing board is now free to be removed and replaced.
      FixBotに聞いてみる
      コメントを追加
    1. Sony DVP-SR200P DVD Reader Replacement, DVD Drive: 手順 7、 1の画像 1
      • Orient the DVD player so the front of the DVD player is opposite of you.
      • Remove the two #1 Phillips screws (silver, 3/16") that attach the DVD drive to the bottom of the DVD player.
      FixBotに聞いてみる
      コメントを追加
    2. Sony DVP-SR200P DVD Reader Replacement: 手順 8、 1の画像 1
      • Remove the DVD drive by pulling it backward and upward while ensuring that it is free of any braces.
      FixBotに聞いてみる
      コメントを追加
    1. Sony DVP-SR200P DVD Reader Replacement, DVD Reader: 手順 9、 3の画像 1 Sony DVP-SR200P DVD Reader Replacement, DVD Reader: 手順 9、 3の画像 2 Sony DVP-SR200P DVD Reader Replacement, DVD Reader: 手順 9、 3の画像 3
      • Flip the DVD drive upside down, to match the orientation of the first picture.
      • Carefully remove the white ribbon cable from the brace holding it in place by sliding it out towards you.
      • Next remove the brace from the DVD drive. Carefully wiggle and pull the brace upward as the white ribbon cable slides out through the brace.
      FixBotに聞いてみる
      コメントを追加
    2. Sony DVP-SR200P DVD Reader Replacement: 手順 10、 1の画像 1
      • Remove the four silver #1 Phillips 3/16''screws to free the DVD reader from the DVD drive.
      FixBotに聞いてみる
      コメントを追加
    3. Sony DVP-SR200P DVD Reader Replacement: 手順 11、 1の画像 1
      • Remove the DVD reader from the DVD drive by pulling it upwards off of the drive.
      • The DVD reader can now be replaced.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
3 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Jose Coronel
メンバー登録日: 01/11/13
84 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 5-17, Forte Winter 2013 Cal Poly, Team 5-17, Forte Winter 2013人のメンバー
CPSU-FORTE-W13S5G17
5 メンバー
24のガイドは作成済み
1件のガイドコメント
Which part help to play games in dvd player
WWE Final Fighters - 返信 共有
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 10
過去 30 日: 52
今までの合計 5,593
